SendStringToExecute eBufferTooSmall
I'm trying to make a list of atoms in AutoLISP console. In Acad 2011, it works fine, in 2008 I got this exception:
I think it because AutoLISP sting is too long. Maybe some options of 2008 Acad to change maximum string size available? Plase help.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eBufferTooSmall
   at Autodesk.AutoCAD.Runtime.Interop.Check(Int32 returnValue)
   at Autodesk.AutoCAD.ApplicationServices.Document.SendStringToExecute(String command, Boolean activate, Boolean wrapUpInactiveDoc, Boolean echoCommand)
   at PutSpecificationIntoDrawing.MainClass.PutSpecification()
   at AcMgCommandClass.InvokeWorker(AcMgCommandClass* , MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at AcMgCommandClass.InvokeWorkerWithExceptionFilter(AcMgCommandClass* , MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at AcMgPerDocumentCommandClass.Invoke(AcMgPerDocumentCommandClass* , gcroot<System::Reflection::MethodInfo ^>* mi, Boolean bLispFunction)
   at AcMgCommandClass.CommandThunk.Invoke(CommandThunk* )
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
acdbmgd
    Assembly Version: 17.1.0.0
    Win32 Version: 17.1.51.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcdbMgd.DLL
msvcm80
    Assembly Version: 8.0.50727.4927
    Win32 Version: 8.00.50727.4927
    CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_88dce9872fb1...
acmgd
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/acmgd.DLL
System.Windows.Forms
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.F...
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
mscorlib.resources
AcInfoCenterConn
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcInfoCenterConn.DLL
AdInfoCenter
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AdInfoCenter.DLL
Autodesk.Interop.AcInetEngine
    Assembly Version: 17.1.51.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/Autodesk.Interop.AcInetEngine.DLL
AdInfoCenter.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/en-US/AdInfoCenter.resources.DLL
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configura...
abwkn5ot
AcLayer
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcLayer.DLL
AcMgdShared
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/AcMgdShared.DLL
acmgdinternal
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/acmgdinternal.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%202008/en-US/AcLayer.resources.DLL
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Mala1805/Desktop/equiptest/PutSpecificationIntoDrawing.dll
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.4926 built by: NetFXw7
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Data
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions...
System.EnterpriseServices
    CodeBase: file:///C:/Windows/assembly/GAC_64/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.Enterp...
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Update: this exception raises when I try to append  12-th element to list of 11 elements from .NET in Acad 2008 like this:
currentDocument.SendStringToExecute("(setq test ()) ", true, false, false);
 for (int i = 0; i < 100; i++)
 currentDocument.SendStringToExecute("(setq test (append test (list \"" + i.ToString() + "\")) ) ", true, false, false);
when i exceeds 11 I have exception.
Ok, i've found solution independently. I just tried to send AutoLISP commands by small pieces in behalf of invisible Windows form, exactly like multithreading described in this post. So I can transfer huge amounts of data from .NET applications to AutoLISP applications in Acad 2008.
