SendStringToExecute and echoCommand
I've searched a lot, but I didn't find any solution for my problem.
I've function written in C#:
    [CommandMethod("GDF")]
        public void doDimLinear()
            DF.doDimLinear();
 In DF class, in doDimLinear function at the end I have:
doc.SendStringToExecute("dimlinear ", false, false, false);
And everything works OK, my function is switching layer, setting dimension style and invoking dimlinear function.
But when I want to repeat last command (by spacebar, right mouse) I have dimlinear command instead of GDF.
Can anyone help me?
Hallex
My guees is you have to use acedCmd instead
Search for this  method here
http://adndevblog.typepad.com/autocad/
Quick example, works good on A2010
        [System.Security.SuppressUnmanagedCodeSecurity]
        [DllImport("acad.exe", EntryPoint = "acedCmd", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl)]
        extern static private int acedCmd(IntPtr resbuf);
        [CommandMethod("dimlin")]
        public void acedCmdDimLinear()
            ResultBuffer rb = new ResultBuffer();
            // RTSTR = 5005
            rb.Add(new TypedValue(5005, "_.DIMLINEAR"));
            // start the insert command
            acedCmd(rb.UnmanagedObject);
            bool quit = false;
            // loop round while the insert command is active
            while (!quit)
                // see what commands are active
                string cmdNames = (string)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("CMDNAMES");
                // if the INSERT command is active
                if (cmdNames.ToUpper().IndexOf("DIMLINEAR") >= 0)
                    // then send a PAUSE to the command line
                    // RTSTR = 5005 - send a user 3 pause to the command line
                    rb.Add(new TypedValue(5005, "\\")); rb.Add(new TypedValue(5005, "\\")); rb.Add(new TypedValue(5005, "\\"));
                else
                    // otherwise quit
                    quit = true;
Seems to work:
            // RTSTR = 5005
            rb.Add(new TypedValue(5005, "_.dimlinear"));
            utilities.acedCmd(rb.UnmanagedObject);
Thank you!
Hallex
Glad you get it worked
Cheers 🙂
