SelectObjects from Listview
Sgear
Sgear
Hi
I am try to select object from Listview but I get = Value of Type cannot be convert to '1-dimensional array
 Autodesk.AutoCAD.Internal.Utils.SelectObjects(ListView.SelectedItems.Item(0).SubItems(1).Text)
Regards
Sgear
Keith.Brown
What is in the list of your treeview?  Are you listing the objects Handles, ObjectId, or something else?  SelectObjects method takes an array of ObjectIds.  You are passing it a string which will not work.
You can use the Editor.SetImpliedSelection method to select your objects in a drawing.  The method takes an array of ObjectId's.
For instance the following code will clear out the pickfirst selection set.
editor.SetImpliedSelection(New ObjectId() {})
You can do the same thing with the method you are trying to use.
Autodesk.AutoCAD.Internal.Utils.SelectObject(New ObjectId() {})
So in summary,  you must get an array of ObjectId's and pass to the SelectObject method.
Sgear
I add Object to listview include Object ID
I am try to DoubleClick in listview to select Object I select in Listview
Thanks will check out Editor.SetImpliedSelection
           For Each colId In colIds
                Using trans As Transaction = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
                    dbObj = trans.GetObject(colId, OpenMode.ForRead)
                    ObjectIDsave = colId.ToString()
                    If TypeOf (dbObj) Is BlockReference Then
                    Else
                        Dim l As Polyline = DirectCast(dbObj, Polyline)
                        stLength = stLength + l.Length.ToString
                    End If
                    trans.Commit()
                    trans.Dispose()
                End Using
            Next colId
' Add to listview !
