Selection Set Filter with more than two object filters
jdaltonAWVZ3
jdaltonAWVZ3
I am writing a program that allows the user to select the following objects: MTEXT, TEXT, and MLEADER, and iteratively go through them and edit the text. The problem arises when I try to put all three object types in the selection filter. Below is what I have currently:
Dim peo As New PromptSelectionOptions With {
        .MessageForAdding = vbLf & "Select Text, Mtext, or MLeader to adjust text: ",
        .MessageForRemoval = vbLf & "Select to Remove: "
Dim filterList As New List(Of TypedValue)
filterList.Add(New TypedValue(DxfCode.Operator, "<OR"))
filterList.Add(New TypedValue(DxfCode.Start, "MTEXT"))
filterList.Add(New TypedValue(DxfCode.Start, "TEXT"))
filterList.Add(New TypedValue(DxfCode.Start, "MLEADER"))
Dim acSelFtr As SelectionFilter = New SelectionFilter(filterList.ToArray())
Dim selectedResult As PromptSelectionResult = acEd.GetSelection(peo, acSelFtr)
If selectedResult.Status <> PromptStatus.OK Then Exit Sub
When I run it in the current configuration is the program stops before it actually gets the selection, making me think that my filter is set up incorrectly. I could not find any examples online of a filter containing three objects or more.
Much help would be appreciated! Thanks!
_gile
Try like this:
filterList.Add(New TypedValue(DxfCode.Operator, "OR>"))
Or simply:
filterList.Add(New TypedValue(DxfCode.Start, "TEXT,MTEXT,MLEADER"))
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
daniel_cadext
use a comma, and wildcards
(Db.DxfCode.kDxfStart, "*TEXT,*LEADER")
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
