Selection Set Filter - Block Name CONTAINS
David_Prontnicki
Message 1 of 11
David_Prontnicki
I know its possible to set a filter list for a block and its name by doing the following:
Dim filterlist As TypedValue() = New TypedValue(1) {}
            filterlist(0) = New TypedValue(0, "INSERT")
            filterlist(1) = New TypedValue(2, "ABC")
 But is it possible to set a filter list by "Contains"? Meaning only select blocks (Dynamic or static) that name contains "-SIGN-". So the block name may be XXXX-SIGN-XXXX-XXX. And it will only allow for the selection of blocks that name contains "-SIGN-".
Thank you in advance.
Replies (10)
Message 2 of 11
_gile
In selction filters, the values of type string honor the wild-card patterns.
new TypedValue(2, "*-SIGN_*");
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 11
David_Prontnicki
@_gile  As always, thank you so much! You are the best! 🙂
Message 4 of 11
David_Prontnicki
@_gile
Hey sorry But it does not seem to be working. I have tried all three below with no luck. It will not select the blocks. (Note some are Dynamic and some are static) But it doesn't select either. It works perfect with the single Typed Value Dim acSelectionFilterAll = New TypedValue() {New TypedValue(0, "INSERT")}
Dim acPromptSelectionOptionsAll As PromptSelectionOptions = New PromptSelectionOptions()
        Dim acSelectionFilterAll = New SelectionFilter({New TypedValue(0, "INSERT"), New TypedValue(2, "*-SIGN-*")})
        acPromptSelectionOptionsAll.MessageForAdding = "Please Select ALL Traffic Sign Details: "
        acPromptSelectionOptionsAll.MessageForRemoval = "Select a Traffic Sign Detail to remove: "
        Dim acPromptSelectionResultsAll As PromptSelectionResult = acCurrentEditor.GetSelection(acPromptSelectionOptionsAll, acSelectionFilterAll)
        Dim acSelectionFilterAll As TypedValue() = New TypedValue(1) {New TypedValue(0, "INSERT"), New TypedValue(2, "*-SIGN-*")}
        Dim acPromptSelectionResultsAll As PromptSelectionResult = acCurrentEditor.GetSelection(acPromptSelectionOptionsAll, New SelectionFilter(acSelectionFilterAll))
        Dim acSelectionFilterAll As TypedValue() = New TypedValue(1) {}
        acSelectionFilterAll(0) = New TypedValue(0, "INSERT")
        acSelectionFilterAll(1) = New TypedValue(2, "*-SIGN-*")
Message 5 of 11
Norman_Yuan
Dynamic BlockReference  cannot be selected by your block name filter, because its name is something like "*Uxxxx". If you want to get a SelectionSet to select block references which could be/include dynamic ones, you should avoid using block name filter. Instead, you identify them after the selectionset is returned and you loop through them in following code.
Norman Yuan
Drive CAD With Code
Message 6 of 11
_gile
As @Norman_Yuan said, you cannot directly filter anonymous blocks (*Uxxx blocks) with a selection filter.
You have to select also all the anoynmous blocks and check for each selected block if the name of its DynamicBlockTableRecord (AKA effective name) matches with your pattern.
 Here's an example:
[CommandMethod("TEST1")]
public static void Test1()
    var ed = Application.DocumentManager.MdiActiveDocument.Editor;
    var filter = new SelectionFilter(new[] {
        new TypedValue(0, "INSERT"),
        new TypedValue(2, "`*U*,*-SIGN-*") });
    var psr = ed.GetSelection(filter);
    if (psr.Status == PromptStatus.OK)
        var db = HostApplicationServices.WorkingDatabase;
        using (var tr = db.TransactionManager.StartTransaction())
            var ids = new ObjectIdCollection();
            // filter anonymous blocks
            foreach (var id in psr.Value.GetObjectIds())
                var br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                string effectiveName =
                    ((BlockTableRecord)tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead)).Name;
                if (Autodesk.AutoCAD.Internal.Utils.WcMatchEx(effectiveName, "*-SIGN-*", true))
                    ids.Add(id);
            var selectedIds = new ObjectId[ids.Count];
            ids.CopyTo(selectedIds, 0);
            ed.SetImpliedSelection(selectedIds);
            tr.Commit();
You can also do this 'on the fly' by handling the Editor.SelectionAdded event:
[CommandMethod("TEST2")]
public static void Test2()
    ed.SelectionAdded += SelectionAdded;
    ed.SelectionAdded -= SelectionAdded;
        ed.SetImpliedSelection(psr.Value);
private static void SelectionAdded(object sender, SelectionAddedEventArgs e)
    using (var tr = new OpenCloseTransaction())
        for (int i = 0; i < e.AddedObjects.Count; i++)
            var br = (BlockReference)tr.GetObject(e.AddedObjects[i].ObjectId, OpenMode.ForRead);
            if (!Autodesk.AutoCAD.Internal.Utils.WcMatchEx(effectiveName, "*-SIGN-*", true))
                e.Remove(i);
Gilles Chanteau
GileCAD
GitHub
Message 7 of 11
David_Prontnicki
@_gile
OK So its sort of working now, it is filtering but it is now bypassing the second prompt. I turned your test1 into a function to return the objectid collection and run a for each on all of them. The problem I have is it now skips the second prompt and leaves the objects selected at the end of the command. Im sure its something simple stupid. 🙂
I belive I need to convert the objectID collection to a selection set. Just not sure how to do that.
Fucntion:
Private Function FilterDetails(ByVal acPromptSelectionResultsAll As PromptSelectionResult)
        Dim ids = New ObjectIdCollection()
        Using acTranaction As Transaction = Active.Database.TransactionManager.StartTransaction()
            For Each id In acPromptSelectionResultsAll.Value.GetObjectIds()
                Dim br = CType(acTranaction.GetObject(id, OpenMode.ForRead), BlockReference)
                Dim effectiveName As String = (CType(acTranaction.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead), BlockTableRecord)).Name
                If Autodesk.AutoCAD.Internal.Utils.WcMatchEx(effectiveName, "*-SIGN-*", True) Then ids.Add(id)
            Next
            Dim selectedIds = New ObjectId(ids.Count - 1) {}
            acCurrentEditor.SetImpliedSelection(selectedIds)
            acTranaction.Commit()
        End Using
        Return ids
    End Function
Sub:
Public Sub SelectDetails()
        Dim acSelectionFilterAll = New SelectionFilter({New TypedValue(0, "INSERT"), New TypedValue(2, "`*U*,*-SIGN-*")})
        If acPromptSelectionResultsAll.Status = PromptStatus.OK Then
            Dim acSelectionSetAllFiltered = FilterDetails(acPromptSelectionResultsAll)
            Dim acPromptSelectionOptionsExisting As PromptSelectionOptions = New PromptSelectionOptions()
            Dim acSelectionFilterExisting = New SelectionFilter({New TypedValue(0, "INSERT"), New TypedValue(2, "`*U*,*-SIGN-*")})
            acPromptSelectionOptionsExisting.MessageForAdding = "Please Select the Traffic Sign Details to be Exiting: "
            acPromptSelectionOptionsExisting.MessageForRemoval = "Select a Traffic Sign Detail to remove: "
            Dim acPromptSelectionResultsExisting As PromptSelectionResult = acCurrentEditor.GetSelection(acPromptSelectionOptionsExisting, acSelectionFilterExisting)
            If acPromptSelectionResultsExisting.Status = PromptStatus.OK Then
                Dim acSelectionSetExistingFiltered = FilterDetails(acPromptSelectionResultsExisting)
                CreateDetailLayer("G-DTLS-TRAF-SIGN-EXST", 253, "G04030(253)", "Details: Traffic Sign Details - Existing")
                CreateDetailLayer("G-DTLS-TRAF-SIGN-PROP", 3, "B025(11)", "Details: Traffic Sign Details - Proposed")
                For Each acSelectedObjectId In acSelectionSetAllFiltered
                    If Not IsDBNull(acSelectedObjectId) Then
                        SetDetailState(acSelectedObjectId, "G-DTLS-TRAF-SIGN-PROP")
                    End If
                Next
                For Each acSelectedObjectId In acSelectionSetExistingFiltered
                        SetDetailState(acSelectedObjectId, "G-DTLS-TRAF-SIGN-EXST")
                    End If
                Next
            Else
                For Each acSelectedObject In acSelectionSetAllFiltered
                    If Not IsDBNull(acSelectedObject) Then
                        SetDetailState(acSelectedObject, "G-DTLS-TRAF-SIGN-PROP")
                    End If
                Next
            End If
            FreezeDetailGridLayers()
        End If
        acCurrentEditor.Regen()
    End Sub
It appears to be doing the following to all selected:
                    End If
                Next
Message 8 of 11
_gile
If you absolutely need a selection set you can  create a new one frolm an ObjetcId array using the SelectionSet.FromObjectIds static method.
Gilles Chanteau
GileCAD
GitHub
Message 9 of 11
David_Prontnicki
@_gile
I apologize, I do not follow how to achieve that?
SelectionSet.FromObjectIds is not an option.
Message 10 of 11
_gile
Here's an example:
                            ids.Add(id);
                    // convert the ObjectIdCollection into an ObjectId array
                    // convert the ObjectId array into a SelectionSet
                    var selectionSet = SelectionSet.FromObjectIds(selectedIds);
                    // grip the selection set
                    ed.SetImpliedSelection(selectionSet);
                    tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 11 of 11
David_Prontnicki
@_gile
Thank you very much, I ended up having the same problem. What I found was if I removed the line,
from the function, it worked as it should. That was causing the program to skip the next prompt.
So long story short it is working. Thank you again for all your help!!
