Selecting Multiple Nested Entities
WonkaPet
WonkaPet
Hi there,
I'm trying to figure out if it's possible to select multiple nested entities with a crossing window.
Using PromptNestedEntityOptions I'm able to select individual nested entities but I'd like to be able to select multiple and I haven't been able to find a solution.
WonkaPet
Thanks @Norman_Yuan I was able to do something similar prior using a crossing window to find everything within the bounds but it was a more "rugged" solution. I looked over your new posts and will be implementing your method which is a lot less code.
Thank you!
