Selecting an Object using its ObjectID via WPF
BKSpurgeon
Message 1 of 11
BKSpurgeon
I am using WPF within the .net API.
What I am trying to do:
  1. I have a list of object Ids.
  2. I am displaying this list to the user.
  3. Upon the user clicking a button, I want the associated ObjectId to be selected.
Right now, I am able to zoom in on the relevant object, but for some reason, I can’t seem to select the actual object itself. The below code runs when the button is clicked:
any assistance much appreciated
public void SelectEntity(ObjectId objectId)
            using (Transaction tr = objectId.Database.TransactionManager.StartTransaction())
                    // I want to zoom in on the relevant object Id - this works fine
                Entity en = tr.GetObject(objectId, OpenMode.ForRead) as Entity;
                Extents3d extents = en.GeometricExtents;
                Plane plane = new Plane(Point3d.Origin, Vector3d.ZAxis);
                Point2d max = extents.MaxPoint.Convert2d(plane);
                Point2d min = extents.MinPoint.Convert2d(plane);
                string lower =   min.ToString().Substring( 1, min.ToString().Length - 2 );
                string upper =   max.ToString().Substring(1,max.ToString().Length - 2 );
                tr.Commit();
                string cmd = "ZOOM _W " + lower + " " + upper + " ";
                Application.DocumentManager.MdiActiveDocument.SendStringToExecute(cmd, false, false, false);
                    // Now I am trying to select the relevant ObjectId but the below attempts
                    // are not working and I have no idea why.
                    // any assistance much appreciated.
                Application.DocumentManager.MdiActiveDocument.Editor.SetImpliedSelection(new ObjectId[1] { objectId });
                Application.DocumentManager.MdiActiveDocument.Editor.GetSelection();
                Autodesk.AutoCAD.Internal.Utils.SelectObjects(new ObjectId[1] { objectId });
Replies (10)
Message 2 of 11
ActivistInvestor
SendStringToExecute() doesn't execute the commands you pass it, until after your function returns, so the commands are executing after the setting of the Pickfirst selection set, and the execution of the commands are causing the selected object to be unselected.
If you select an object with your mouse and then issue the zoom command, after the zoom command has finished, is the object still selected?
Wrap your code inside of a command method, and get rid of the calls to SendStringToExecute(), replacing them with calls to Editor.Command(), and then execute your command method from your button click handler using SendStringToExecute().
Set the CommandFlags.Redraw flag on the CommandMethod, so that the command can leave objects selected when it ends.
                tr.Commit();
Message 3 of 11
BKSpurgeon
Thank you for your answer Activist.
I have a clarification to make:
Given the new command method ZoomToEntity below, would you know how I can pass an objectId to this method?
As I understand it, all command methods must be in a single class with a commandclass attribute. so i cannot register such a method from within my user control.
Would you know how I can pass an objectId to the ZoomEntity method from within my button event handler (which is located in the PanelHighlighter class (of type UserControl) as you've suggested above?
Any advice much appreciated.
        [CommandMethod("ZoomToEntity", CommandFlags.Redraw)]
        public void ZoomToEntity()
                 // I can put the code here, but any ideas how to pass in an objectId to here?
private static PaletteSet ps = null;
public static PanelHighlighter ph = null; // UI - i.e. UserControl
[CommandMethod("CPWin", CommandFlags.Redraw)] public void CPWin() { try { if (ps == null) { ps = new PaletteSet("Comp"); ph = new PanelHighlighter(); ps.AddVisual("Comp", ph); } ps.Visible = true; } catch (System.Exception ex) { if (ex.Message.ToUpper() == "FAIL SILENTLY") { } else { System.Windows.MessageBox.Show(ex.Message); } } }
Message 4 of 11
_gile
Here's a way.
In the Commands class
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace AutoCadWpfPaletteSample
    public class Commands
        static CustomPaletteSet palette;
        [CommandMethod("SHOWPALETTE")]
        public void ShowPalette()
            if (palette == null)
                palette = new CustomPaletteSet();
            palette.Visible = true;
            var id = palette.Tab.SelectedId;
            if (!id.IsNull)
                using (var tr = new OpenCloseTransaction())
                    var entity = (Entity)tr.GetObject(id, OpenMode.ForRead);
                    var extents = entity.GeometricExtents;
                    dynamic acadApp = Application.AcadApplication;
                    acadApp.ZoomWindow(extents.MinPoint.ToArray(), extents.MaxPoint.ToArray());
                    acadApp.ZoomScaled(0.8, 1);
                    var ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
                    ed.SetImpliedSelection(new[] { id });
The CustomPaletteSet class
using Autodesk.AutoCAD.Windows;
using System;
    public class CustomPaletteSet : PaletteSet
        public PaletteTab Tab { get; }
        public CustomPaletteSet()
            : base("Palette", "SHOWPALETTE", new Guid("{034E96B4-20D7-4BA7-9CF6-E2E6923E84A3}"))
            Tab = new PaletteTab();
            Style = PaletteSetStyles.ShowAutoHideButton |
                    PaletteSetStyles.ShowCloseButton |
                    PaletteSetStyles.ShowPropertiesMenu;
            MinimumSize = new System.Drawing.Size(250, 150);
            AddVisual("Tab", Tab);
The PaletteTab XAML (only Bindings)
<UserControl x:Class="AutoCadWpfPaletteSample.PaletteTab"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:local="clr-namespace:AutoCadWpfPaletteSample"
             mc:Ignorable="d"
             d:DesignHeight="150" d:DesignWidth="250">
    <Grid Background="WhiteSmoke">
        <Grid.RowDefinitions>
            <RowDefinition Height="*"/>
            <RowDefinition Height="Auto"/>
        </Grid.RowDefinitions>
        <ListBox Width="200" ItemsSource="{Binding Ids}" SelectedItem="{Binding SelectedId}" />
        <Button Grid.Row="1" Margin="10" Width="100" Click="CmdButton_Click">Zoom To Entity</Button>
    </Grid>
</UserControl>
The code behind
using System.ComponentModel;
using System.Windows;
using System.Windows.Controls;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
    public partial class PaletteTab : UserControl, INotifyPropertyChanged
        public event PropertyChangedEventHandler PropertyChanged;
        public void RaisePropertyChanged(string propertyName)
            PropertyChanged?.Invoke(this, new PropertyChangedEventArgs(propertyName));
        ObjectId[] ids;
        ObjectId selectedId;
        public ObjectId[] Ids
            get { return ids; }
            set { ids = value; RaisePropertyChanged(nameof(Ids)); }
        public ObjectId SelectedId
            get { return selectedId; }
            set { selectedId = value; RaisePropertyChanged(nameof(SelectedId)); }
        public PaletteTab()
            InitializeComponent();
            DataContext = this;
        private void CmdButton_Click(object sender, RoutedEventArgs e)
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            doc.SendStringToExecute("ZoomToEntity ", false, false, false);
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 5 of 11
_gile
A more MVVM way.
XAML
<UserControl x:Class="ZoomToEntityPaletteSample.PaletteTab"
             xmlns:local="clr-namespace:ZoomToEntityPaletteSample"
             mc:Ignorable="d"
        <ListBox Margin="10" Width="200" ItemsSource="{Binding Ids}" SelectedItem="{Binding SelectedId}"/>
        <Button Grid.Row="1" Margin="10" Width="100" Command="{Binding ButtonCmd}">Zoom to Entity</Button>
    </Grid>
</UserControl>
Code behind
namespace ZoomToEntityPaletteSample
        public PaletteTab()
            DataContext = new PaletteTabViewModel();
The CustomPaletteSet class (with auto hide in zero doc state behavior)
using System;
        bool wasVisible, hiddenInZeroDocState;
            : base("Palette", "SHOWPALETTE", new Guid("{9E7570A4-CFDB-4843-A035-C0B892B695C4}"))
            AddVisual("Tab 1", new PaletteTab());
            // hide the palette in zero document state
            var docs = Application.DocumentManager;
            Application.QuitWillStart += (s, e) => Visible = Visible || hiddenInZeroDocState;
            docs.DocumentActivated += (s, e) => Visible = e.Document == null ? false : wasVisible;
            docs.DocumentCreated += (s, e) => Visible = wasVisible;
            docs.DocumentToBeDeactivated += (s, e) => wasVisible = Visible;
            docs.DocumentToBeDestroyed += (s, e) =>
                if (docs.Count == 1 && Visible)
                    hiddenInZeroDocState = true;
                    Visible = false;
In the command class, the ZoomToEntity command can be run independently to the palette by prompting the user to select an entity or, use the implied selection if it contains a single entity (CommandFlags.UsePickSet).
        static PaletteSet palette;
        public void CmdPalette()
        [CommandMethod("ZoomToEntity", CommandFlags.UsePickSet | CommandFlags.NoPaperSpace | CommandFlags.Redraw)]
            if (ed.SelectImplied().Status == PromptStatus.OK &&
                ed.SelectImplied().Value.Count > 1)
                ed.SetImpliedSelection(new ObjectId[0]);
            var options = new PromptSelectionOptions();
            options.SelectEverythingInAperture = true;
            options.SingleOnly = true;
            var sel = ed.GetSelection(options);
            if (sel.Status == PromptStatus.OK)
                    var entity = (Entity)tr.GetObject(sel.Value[0].ObjectId, OpenMode.ForRead);
                ed.SetImpliedSelection(sel.Value);
The PaletteTabViewModel class.
As we do not know how you get the ObjectId to fill the list box, here it gets all entities in model space.
The Cmd() method (the action of the ICommand property bound to the button) calls SetImpliedSelection with the selected ObjectId before calling the ZoomToEntity command.
using System.Collections.Generic;
using System.Linq;
    public class PaletteTabViewModel : INotifyPropertyChanged
        IEnumerable<ObjectId> ids;
        public PaletteTabViewModel()
            var docs = AcAp.DocumentManager;
            Ids = GetIds(docs.MdiActiveDocument);
            foreach (Document doc in docs)
                doc.Database.ObjectAppended += (s, e) => Ids = GetIds(doc);
                doc.Database.ObjectErased += (s, e) => Ids = GetIds(doc);
            docs.DocumentActivated += (s, e) => Ids = GetIds(e.Document);
            AcAp.DocumentManager.DocumentCreated += (sender, e) =>
                var doc = e.Document;
                doc.Database.ObjectAppended += (s, _) => Ids = GetIds(doc);
                doc.Database.ObjectErased += (s, _) => Ids = GetIds(doc);
        public IEnumerable<ObjectId> Ids
            get { return ids; }
        public RelayCommand ButtonCmd =>
            new RelayCommand((_) => Cmd(), (_) => !SelectedId.IsNull);
        private void Cmd()
            if (doc != null)
                doc.Editor.SetImpliedSelection(new[] { selectedId });
        private IEnumerable<ObjectId> GetIds(Document doc)
                var ms = (BlockTableRecord)tr.GetObject(
                    SymbolUtilityServices.GetBlockModelSpaceId(doc.Database), OpenMode.ForRead);
                return ms.Cast<ObjectId>();
        #region INotifyPropertyChanged
        public void RaisePropertyChanged(string propertyName) =>
        #endregion
The RelayCommand class is an helper which implements ICommand.
using System;
using System.Windows.Input;
    public class RelayCommand : ICommand
        readonly Action<object> execute;
        readonly Predicate<object> canExecute;
        public RelayCommand(Action<object> execute, Predicate<object> canExecute = null)
            this.execute = execute ?? throw new ArgumentNullException("execute");
            this.canExecute = canExecute ?? (o => true);
        public void Execute(object parameter) => execute(parameter);
        public bool CanExecute(object parameter) => canExecute(parameter);
        public event EventHandler CanExecuteChanged
            add { CommandManager.RequerySuggested += value; }
            remove { CommandManager.RequerySuggested -= value; }
Gilles Chanteau
GileCAD
GitHub
Message 6 of 11
_gile
Oops...
In the upper message, the Commands class shoud have been this:
            ObjectId id = ObjectId.Null;
            if (ed.SelectImplied().Status == PromptStatus.OK && ed.SelectImplied().Value.Count == 1)
                id = ed.SelectImplied().Value[0].ObjectId;
            else
                    id = sel.Value[0].ObjectId;
            if (!id.IsNull)
Gilles Chanteau
GileCAD
GitHub
Message 7 of 11
ActivistInvestor
First, to clarify what you wrote below, all command methods do not have to be in a single class with a CommandClass attribute.
You can place command methods in any number of classes, but if you use the CommandClass attribute anywhere in the assembly, then there must be one CommandClass attribute for every class that contains command methods.
What you need to be careful with is the scope of your CommandMethods. Unless there is a good reason for it, you should declare CommandMethods as static methods, rather than instance methods. If a command method is not static, AutoCAD is going to create an instance of the containing class for each open document in which the command is used. So in fact, you can declare a static command method on your UserControl class, but that isn't going to solve the problem, because the command method is static and it doesn't have access to the instance of the UserControl in which the data is obtained from.
A simple and direct way to access the ObjectId from the ZoomToEntity() command method, is to declare a static class, with a single static property of the type ObjectId, and before you call SendStringToExecute() to invoke the ZoomToEntity() command method, you assign the ObjectId to the static property of the static class, and then from the ZoomToEntity() command method, you can read that same property. The static class where you store the ObjectId could be nothing more than this:
public static class ZoomToEntityData { public static ObjectId EntityId {get; set;} }
Message 8 of 11
_gile
A better MVVM implementation.
Commands class
        [CommandMethod("ZOOMPALETTE")]
        public static void ZoomPalette()
        [CommandMethod("ZOOMTOENTITY", CommandFlags.UsePickSet | CommandFlags.Redraw)]
        public static void ZoomToEntity()
            SelectionSet selection = null;
                selection = ed.SelectImplied().Value;
            else
                    selection = sel.Value;
            if (selection != null)
                    var entity = (Entity)tr.GetObject(selection[0].ObjectId, OpenMode.ForRead);
                    acadApp.ZoomScaled(0.9, 1);
                ed.SetImpliedSelection(selection);
using Autodesk.AutoCAD.ApplicationServices.Core;
using System;
            : base("Palette", "ZOOMPALETTE", new Guid("{F7082EBA-AE90-4EE7-98A6-EA04ADEFFEC5}"))
            MinimumSize = new System.Drawing.Size(230, 150);
            AddVisual("ZoomTab", new PaletteTab());
                    Visible = false;
PaletteTab XAML
<UserControl x:Class="ZoomToEntityPalette.PaletteTab"
             xmlns:local="clr-namespace:ZoomToEntityPalette"
             mc:Ignorable="d"
             d:DesignHeight="150" d:DesignWidth="220">
        <ListBox Margin="10" Width="200" ItemsSource="{Binding ObjectIds}" DisplayMemberPath="ObjectClass.DxfName" SelectedItem="{Binding SelectedId}"/>
        <Button Grid.Row="1" Margin="10" Width="100" Command="{Binding ZoomCommand}">Zoom to Entity</Button>
    </Grid>
</UserControl>
PaletteTab code behind
        public PaletteTab()
using System.Collections.ObjectModel;
using System.Linq;
    public class PaletteTabViewModel : ObservableObject
        ObservableCollection<ObjectId> ids;
        ObjectId? selectedId;
            docs.DocumentActivated += (s, e) => GetIds(e.Document);
            foreach (Document doc in docs) AddHandlers(doc);
            AcAp.DocumentManager.DocumentCreated += (s, e) => AddHandlers(e.Document);
        public ObservableCollection<ObjectId> ObjectIds
            get { return ids; }
            set { ids = value; RaisePropertyChanged(nameof(ObjectIds)); }
        public ObjectId? SelectedId
        public RelayCommand ZoomCommand =>
            new RelayCommand((_) => ExecuteZoomCommand(), (_) => selectedId.HasValue);
        private void ExecuteZoomCommand()
            if (doc != null)
                doc.Editor.SetImpliedSelection(new[] { selectedId.Value });
                SelectedId = null;
        private void AddHandlers(Document doc)
            var db = doc.Database;
            db.ObjectAppended += (s, e) =>
                if (e.DBObject.OwnerId == db.CurrentSpaceId)
                    ObjectIds.Add(e.DBObject.ObjectId);
            db.ObjectErased += (s, e) =>
                    if (ids.Contains(e.DBObject.ObjectId))
                        ObjectIds.Remove(e.DBObject.ObjectId);
                    else
            doc.LayoutSwitched += (s, e) => GetIds(doc);
            doc.CommandEnded += (s, e) =>
                if(e.GlobalCommandName == "MSPACE" || e.GlobalCommandName == "PSPACE")
                    GetIds(doc);
        private void GetIds(Document doc)
                try
                    var space = (BlockTableRecord)tr.GetObject(doc.Database.CurrentSpaceId, OpenMode.ForRead);
                    ObjectIds = new ObservableCollection<ObjectId>(space.Cast<ObjectId>());
                catch (Exception e) when (e.ErrorStatus == ErrorStatus.NullObjectId) { }
                catch { throw; }
View Model helper classes
    public class ObservableObject : INotifyPropertyChanged
        protected void RaisePropertyChanged(string propertyName)
using System;
Gilles Chanteau
GileCAD
GitHub
Message 9 of 11
ActivistInvestor
 Hi @_gile
You really don't want to call SelectImplied() 3 times redundantly, because it has to do a lot of work.
Commands class
            else
Message 10 of 11
_gile
@ActivistInvestor wrote:
 Hi @_gile
Thank you for the remark, it must have escaped me when I refactored this code.
            var selectImplied = ed.SelectImplied();
            if (selectImplied.Status == PromptStatus.OK && selectImplied.Value.Count == 1)
                selection = selectImplied.Value;
            else
Gilles Chanteau
GileCAD
GitHub
Message 11 of 11
ActivistInvestor
@_gilewrote:
@ActivistInvestorwrote:
 Hi @_gile
YW, I just wish I had posted the right image, which was supposed to be this one:
