Select polyline in point
Hi. I have a folowwing problem:
I have a lot of polylines. Some polylines are in one point and I want to select these then delete selected objects.
Example point:
Dim c As Double = 359.1275
        Dim point As New Point2d(Val(c), Val(c))
How I would like to select these polyline:
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Using acLckDoc As DocumentLock = acDoc.LockDocument
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Dim acSSPrompt As PromptSelectionResult = acDoc.Editor.GetSelection(""Select all In point"")
                If acSSPrompt.Status = PromptStatus.OK Then
                    Dim acSSet As SelectionSet = acSSPrompt.Value
                    For Each acSSObj As SelectedObject In acSSet
                        If Not IsDBNull(acSSObj) Then
                            Dim acEnt As Entity = acTrans.GetObject(acSSObj.ObjectId, OpenMode.ForWrite)
                            If Not IsDBNull(acEnt) Then
                                acEnt.Erase()
                            End If
                        End If
                    Next
                    acTrans.Commit()
                End If
            End Using
        End Using
but in the "" "" i wrote what i want to select but i don't know how to do it.
Then I would like to choose everything that has not been erase and join it
_gile
If you want to select the polylines crossing a previouly known point without user interaction, you can use the Editor.SelectCrossingWindow passing it the point twice (or two very closed points).
        [CommandMethod("TEST1")]
        public static void Test1()
            var ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            // selection filter to select only Polyline
            var filter = new SelectionFilter(new[] { new TypedValue(0, "LWPOLYLINE") });
            var point = new Point3d(359.1275, 359.1275, 0.0);
            var result = ed.SelectCrossingWindow(point, point, filter);
            // highlight the result
            if (result.Status == PromptStatus.OK)
                ed.SetImpliedSelection(result.Value);
If you want the user to pick a point and select all polylines within the cusor aperture, you can set some PromptSelectionOptions (this also requires to deactivate the selection cycling)
        [CommandMethod("TEST2")]
        public static void Test2()
            var filter = new SelectionFilter(new[] { new TypedValue(0, "LWPOLYLINE") }); ;
            // selection options to select everything in aperture by single pick
            var options = new PromptSelectionOptions();
            options.MessageForAdding = "\nSelect Polylines by point: ";
            options.SelectEverythingInAperture = true;
            options.SingleOnly = true;
            // get the current SELECTIONCYCLING and deactivate it
            var selectionCycling = Application.GetSystemVariable("SELECTIONCYCLING");
            Application.SetSystemVariable("SELECTIONCYCLING", 0);
            try
                // prompt the user for selection
                var result = ed.GetSelection(options, filter);
            // restore the previous value of SELECTIONCYCLING
            finally { Application.SetSystemVariable("SELECTIONCYCLING", selectionCycling); }
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
_gile
Another way without user interaction could be get all entities ObjectId in current space, filter polylines and check for the distance between the search point and the closest point on polyline to the searche point.
        [CommandMethod("Test3")]
        public static void Test3()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var ids = new ObjectIdCollection();
            using (var tr = new OpenCloseTransaction())
                var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                foreach (ObjectId id in curSpace)
                    if (id.ObjectClass.DxfName == "LWPOLYLINE")
                        var pl = (Polyline)tr.GetObject(id, OpenMode.ForRead);
                        if (pl.GetClosestPointTo(point, false).DistanceTo(point) < Tolerance.Global.EqualPoint)
                            ids.Add(id);
                var array = new ObjectId[ids.Count];
                ids.CopyTo(array, 0);
                ed.SetImpliedSelection(array);
                tr.Commit();
This can be written in a more declarative way by using Linq with lambda functions
        [CommandMethod("TEST4")]
        public static void Test4()
                var ids = ((BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite))
                    .Cast<ObjectId>()
                    .Where(id => id.ObjectClass.DxfName == "LWPOLYLINE")
                    .Select(id => (Polyline)tr.GetObject(id, OpenMode.ForRead))
                    .Where(pl => pl.GetClosestPointTo(point, false).DistanceTo(point) < Tolerance.Global.EqualPoint)
                    .Select(pl => pl.ObjectId)
                    .ToArray();
                ed.SetImpliedSelection(ids);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
