select Polyline if I am close to startpoint or endpoint
Sgear
Sgear
Hi
How can I check when I select Polyline if I am close to endpoint or startpoint
<CommandMethod("ADDTEXT")>
        Public Sub test3()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            Dim color As Autodesk.AutoCAD.Colors.Color
            Dim peo As New PromptEntityOptions(vbLf & "Select a polyline: ")
            peo.SetRejectMessage("Selected object is not a polyline.")
            peo.AddAllowedClass(GetType(Polyline), True)
            Dim per As PromptEntityResult = ed.GetEntity(peo)
            If per.Status <> PromptStatus.OK Then
                Return
            End If
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim space As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, Autodesk.Gis.Map.Constants.OpenMode.OpenForWrite), BlockTableRecord)
                Dim pline As Polyline = CType(tr.GetObject(per.ObjectId, Autodesk.Gis.Map.Constants.OpenMode.OpenForRead), Polyline)
                'ed.WriteMessage(vbLf & pline.StartPoint.X.ToString)
                'ed.WriteMessage(vbLf & pline.StartPoint.Y.ToString)
                tr.Commit()
                Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                    '' Open the Block table for read
                    Dim acBlkTbl As BlockTable
                    acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, Autodesk.Gis.Map.Constants.OpenMode.OpenForRead)
                    '' Open the Block table record Model space for write
                    Dim acBlkTblRec As BlockTableRecord
                    acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), Autodesk.Gis.Map.Constants.OpenMode.OpenForWrite)
                    '' Create the MText annotation
                    Using acMText As MText = New MText()
                        acMText.Contents = "Text"
                        acMText.Location = New Point3d(pline.StartPoint.X + 10, pline.StartPoint.Y + 8, 0)
                        '   acMText.Width = 20
                        acMText.TextHeight = 1.5
                        acMText.Layer = "Layer-name"
                        acMText.Attachment = AttachmentPoint.MiddleLeft
                        acMText.BackgroundFill = True
                        color = Color.FromColorIndex(ColorMethod.ByAci, 1)
                        acMText.BackgroundFillColor = color
                        acMText.UseBackgroundColor = True
                        '' Add the new object to Model space and the transaction
                        acBlkTblRec.AppendEntity(acMText)
                        acTrans.AddNewlyCreatedDBObject(acMText, True)
                        '' Create the leader with annotation
                        Using acLdr As Leader = New Leader()
                            acLdr.AppendVertex(New Point3d(pline.StartPoint.X, pline.StartPoint.Y, 0))
                            acLdr.AppendVertex(New Point3d(pline.StartPoint.X + 8, pline.StartPoint.Y + 8, 0))
                            acLdr.AppendVertex(New Point3d(pline.StartPoint.X + 8, pline.StartPoint.Y + 9, 0))
                            acLdr.HasArrowHead = True
                            acBlkTblRec.AppendEntity(acLdr)
                            acTrans.AddNewlyCreatedDBObject(acLdr, True)
                            '' Attach the annotation after the leader object is added
                            acLdr.Annotation = acMText.ObjectId
                            acLdr.EvaluateLeader()
                            acLdr.Layer = "Layer-name"
                        End Using
                    End Using
                    '' Commit the changes and dispose of the transaction
                    acTrans.Commit()
                End Using
            End Using
        End Sub
_gile
The PromptEntityResult class provides a PickedPoint property. You can compare the distance from to this point to the polyline start point and end point (take care the PickedPoint is UCS defined).
Gilles Chanteau
GileCAD
GitHub
