Select Object Command Prompt
mathewkol
Advisor Advisor
Message 1 of 8
mathewkol
I'm creating a VB.Net routine which will run the REVCLOUD command.  In my application I prompt the user to select a single polyline using:
EntRslt = acDoc.Editor.GetEntity(EntOpts)
Then later I run the REVCLOUD command using:
acDoc.SendStringToExecute("_revcloud Object Poly No ", False, False, True)
Where Poly is the polyline I selected earlier.  Of course, the line above doesn't work since "Poly" is interpreted as a string.  But I would like to figure out how to pass my VB.Net selected Polyline into the REVCLOUD command.
Anyone have any advice on how I might do this?  The REVCLOUD command will not accept the "Previous" selection set so setting the Implied Selectoin does not work.  If my Polyline was the Last object in the database I could use the "Last" option, but it isn't.
Thanks in advance.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Replies (7)
Message 2 of 8
Hallex
You better use acedCmd P/Invoke function
Give this a try:
       <DllImport("acad.exe", BestFitMapping:=True, CallingConvention:=CallingConvention.Cdecl, CharSet:=CharSet.Auto)> _
        Private Shared Function acedCmd(ByVal vlist_in As System.IntPtr) As Integer
        End Function
        <CommandMethod("Cloud")> _
        Public Shared Sub TestCloud()
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim doc As Document = acApp.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using tr
                Try
                    ' Prompt for the polyline to revcloud
                    Dim peo As New PromptEntityOptions(vbLf & "Select first polyline:")
                    peo.SetRejectMessage(vbLf & "Select polyline only")
                    peo.AddAllowedClass(GetType(Polyline), True)
                    Dim per As PromptEntityResult = ed.GetEntity(peo)
                    If per.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim fid As ObjectId = per.ObjectId
                    Dim obj1 As DBObject = tr.GetObject(fid, OpenMode.ForWrite)
                    acApp.SetSystemVariable("CMDECHO", 0)
                    Dim buf As New ResultBuffer()
                    buf.Add(New TypedValue(5005, "_REVCLOUD"))
                    buf.Add(New TypedValue(5005, "_O"))
                    buf.Add(New TypedValue(5006, fid))
                    buf.Add(New TypedValue(5005, "_N"))
                    acedCmd(buf.UnmanagedObject)
                    buf.Dispose()
                    acApp.SetSystemVariable("CMDECHO", 1)
                    tr.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                End Try
            End Using
        End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 8
Hallex
I discovered one more method you may want to use,
check this as well, just change the arc sizes in the command string:
        <CommandMethod("Revc", CommandFlags.Modal Or CommandFlags.Session)> _
        Public Shared Sub RevCloudTest()
            acApp.SetSystemVariable("osmode", 512)
            Dim pt As Point3d = ed.GetPoint(vbLf + "Pick a point on polyline: ").Value
            doc.SendStringToExecute("_REVCLOUD _A 0.1 0.3 _O " + pt.X.ToString + "," + pt.Y.ToString + ",0 _N ", True, False, False)
        End Sub
~'J'~
Message 4 of 8
mathewkol
Thank you very much for your reply.  I was able to get your first suggection to line:
I assume it has something to do with the TypedValue TypeCode 5006.  I assume 5005 is a string and 5006 is an ObjectID?  What would the code be for a double?  Is there a list of these codes somewhere?  I have looked and I've not found anythng useful.
buf.Add(New TypedValue(5005, "_OFFSET"))
buf.Add(New TypedValue(5006, OffsetLength))
buf.Add(New TypedValue(5006, Pline.ObjectId))
 Thanks again.
Matt Kolberg
Message 5 of 8
mathewkol
Ok, the offset length is easy, I just use the ToString option.
But of course, in the Offset command I will need to specify a point as well.  5006 does not work; I'm not sure which integer value to use here.
Matt Kolberg
Message 6 of 8
Hallex
Here is some constants for ResultBuffer values:
		' Type of resbuf element
		' credit to Alexander Rivilis
		Const RTNONE As Short = 5000
		' No result
		Const RTREAL As Short = 5001
		' Real number
		Const RTPOshort As Short = 5002
		' 2D poshort X and Y only
		Const RTSHORT As Short = 5003
		' Short integer
		Const RTANG As Short = 5004
		' Angle
		Const RTSTR As Short = 5005
		' String
		Const RTENAME As Short = 5006
		' Entity name
		Const RTPICKS As Short = 5007
		' Pick set
		Const RTORshort As Short = 5008
		' Orientation
		Const RT3DPOshort As Short = 5009
		' 3D poshort - X, Y, and Z
		Const RTLONG As Short = 5010
		' Long integer
		Const RTVOID As Short = 5014
		' Blank symbol
		Const RTLB As Short = 5016
		' list begin
		Const RTLE As Short = 5017
		' list end
		Const RTDOTE As Short = 5018
		' dotted pair
		Const RTNIL As Short = 5019
		' nil
		Const RTDXF0 As Short = 5020
		' DXF code 0 for ads_buildlist only
		Const RTT As Short = 5021
		' T atom
		Const RTRESBUF As Short = 5023
		' resbuf
		Const RTMODELESS As Short = 5027
		' interrupted by modeless dialog
		' Error return code
		Const RTNORM As Short = 5100
		' Request succeeded
		Const RTERROR As Short = -5001
		' Some other error
		Const RTCAN As Short = -5002
		' User cancelled request -- Ctl-C
		Const RTREJ As Short = -5003
		' AutoCAD rejected request -- invalid
		Const RTFAIL As Short = -5004
		' Link failure -- Lisp probably died
		Const RTKWORD As Short = -5005
		' Keyword returned from getxxx() routine
		Const RTINPUTTRUNCATED As Short = -5008
~'J'~
Message 7 of 8
mathewkol
Thank you very much HALLEX, I was able to use your code to fix mine.  It all seems to work now.
Matt Kolberg
Message 8 of 8
Hallex
Glad I could help, Matt
Happy computing 🙂
~'J'~
