Select multiple texts with many annotative scales
hoanggiacf258
hoanggiacf258
I have texts with multiple annotative scales and need to filter and select only those matching a specific scale. Suppose I have a series of texts I want to move—I can manually grab the grip and move them, but with a large quantity, this becomes impractical.
I assumed that using SELECTIONANNODISPLAY would display only the annotative scale I intended to modify—such as 1:30—but when I moved the selected texts, those with other annotative scales changed simultaneously.
How can I select multiple texts and move them simultaneously without affecting the position of texts with a different annotation scale? I’ve tried using filter, quick select, and select similar, but none seem to allow selecting texts based on a specific annotation scale.
Thanks everyone!
Gepaha
See if this helps you.
https://adndevblog.typepad.com/autocad/2015/07/setting-position-of-an-mtext-for-each-annotation-scal...
public void SetMTextPositionByAnnotativeScaleContext()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    string contextNameToMove = "1:50";
    ObjectContextManager ocm = db.ObjectContextManager;
    ObjectContextCollection occ = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES");
    if (ocm == null)
        return;
    if (!occ.HasContext(contextNameToMove))
        return;
    PromptSelectionOptions pso = new PromptSelectionOptions();
    pso.MessageForAdding = "\nSelect MText annotative objects";
    PromptSelectionResult psr = ed.GetSelection(pso);
    if (psr.Status != PromptStatus.OK) return;
    var dbAnnoScale = db.Cannoscale;
    try
        using (Transaction tr = db.TransactionManager.StartTransaction())
            ObjectContext objectContextToMove = occ.GetContext(contextNameToMove);
            foreach (SelectedObject so in psr.Value)
                MText mt = tr.GetObject(so.ObjectId, OpenMode.ForRead) as MText;
                if (mt != null && mt.Annotative == AnnotativeStates.True && mt.HasContext(objectContextToMove))
                    AnnotationScale annoScaleToMove = objectContextToMove as AnnotationScale;
                    Point3d pos = mt.Location;
                    db.Cannoscale = annoScaleToMove;
                    mt.UpgradeOpen();
                    mt.Location = pos + Vector3d.XAxis * mt.TextHeight + Vector3d.YAxis * mt.TextHeight;
            tr.Commit();
    finally
        db.Cannoscale = dbAnnoScale;
