select filter by xdata regappname does not always work
Message 1 of 19
Dear Forum Users;
I've been working with .NET and the AutoCAD API for a while now,
but here's something I really don't get.
I've added an entity to a drawing, that contains the following XData (each line represents a new TypedValue):
type: 1001, value: 200903021622150430002
type: 1002, value: {
type: 1000, value: Somestring
type: 1002, value: }
The value displayed in the first xdata-line is a RegAppName which I have added as a RegAppTableRecord to the RegAppTable.
My drawing is full of entities, but I'd like to find exáctly this entity.
I do this by creating a selection filter and calling the selectAll method on the Autodesk.Autocad.EditorInput.Editor-object.
See the sample code below
{code}
'variable ID is of string value "200903021622150430002"
Dim ent As Entity = nothing
Dim filter As TypedValue() = {New TypedValue(DxfCode.ExtendedDataRegAppName, ID)}
Dim selfilter As New SelectionFilter(filter)
Dim pres As PromptSelectionResult = ed.SelectAll(selfilter)
If Not pres.Value Is Nothing Then
Dim idarray As ObjectId() = pres.Value.GetObjectIds()
If idarray.Length > 0 Then
Using tr As Transaction = db.TransactionManager.StartTransaction
Try
ent = DirectCast(tr.GetObject(idarray(0), OpenMode.ForRead, False), Entity)
Catch ex As System.Exception
Debug.WriteLine(ex.Message)
End Try
End Using
End If
End If
{code}
The Problem;
This method does not álways seem to work.
In most cases, the entity i am looking for will be found and retrieved by from the Database.
However, sometimes PromptSectionResult.Value is just Nothing.
What could be the possible cause of (and solution to) this?
i already tried recovering the drawing, thus no errors might exist in the drawing i guess¿
Also, adding a typedvalue that contains DxfCode.XDataSTart does not make a difference:
Dim filter As TypedValue() = {New TypedValue(DxfCode.XDataStart), New TypedValue(DxfCode.ExtendedDataRegAppName, ID)}
Replies (18)
Message 2 of 19
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Dear
Forum Users; I've been working with .NET and the AutoCAD API for a while now,
but here's something I really don't get. I've added an entity to a drawing,
type: 1001, value: 200903021622150430002 type: 1002, value: { type: 1000,
value: Somestring type: 1002, value: } The value displayed in the first
RegAppTable. My drawing is full of entities, but I'd like to find exáctly this
entity. I do this by creating a selection filter and calling the selectAll
method on the Autodesk.Autocad.EditorInput.Editor-object. See the sample code
below {code} 'variable ID is of string value "200903021622150430002" Dim ent
As Entity = nothing Dim filter As TypedValue() = {New
TypedValue(DxfCode.ExtendedDataRegAppName, ID)} Dim selfilter As New
SelectionFilter(filter) Dim pres As PromptSelectionResult =
ed.SelectAll(selfilter) If Not pres.Value Is Nothing Then Dim idarray As
ObjectId() = pres.Value.GetObjectIds() If idarray.Length > 0 Then Using tr
As Transaction = db.TransactionManager.StartTransaction Try ent =
DirectCast(tr.GetObject(idarray(0), OpenMode.ForRead, False), Entity) Catch ex
As System.Exception Debug.WriteLine(ex.Message) End Try End Using End If End
If {code} The Problem; This method does not álways seem to work. In most
Database. However, sometimes PromptSectionResult.Value is just Nothing. What
could be the possible cause of (and solution to) this? i already tried
difference: Dim filter As TypedValue() = {New TypedValue(DxfCode.XDataStart),
Message 3 of 19
If one is using a newsreader, that doesn't help, and code tags
or not, the entire message content is word-wrapped.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"Kerry Brown" wrote in message
news:[email protected]...
http://discussion.autodesk.com/forums/ann.jspa?annID=125
"plamp" wrote in message news:[email protected]...
Dear Forum Users; I've been working with .NET and the AutoCAD API for a
while now, but here's something I really don't get. I've added an entity to
TypedValue): type: 1001, value: 200903021622150430002 type: 1002, value: {
type: 1000, value: Somestring type: 1002, value: } The value displayed in
RegAppTableRecord to the RegAppTable. My drawing is full of entities, but
I'd like to find exáctly this entity. I do this by creating a selection
Autodesk.Autocad.EditorInput.Editor-object. See the sample code below {code}
'variable ID is of string value "200903021622150430002" Dim ent As Entity =
ex As System.Exception Debug.WriteLine(ex.Message) End Try End Using End If
End If {code} The Problem; This method does not álways seem to work. In most
guess¿ Also, adding a typedvalue that contains DxfCode.XDataSTart does not
make a difference: Dim filter As TypedValue() = {New
Message 4 of 19
This is a test in Rich Text format.
Option Explicit
Private Const MAX_COMPUTERNAME_LENGTH As Long =
31
Private Declare Function GetComputerName Lib "kernel32" Alias
"GetComputerNameA" (ByVal lpBuffer As String, nSize As Long) As
Long
Private Sub Form_Load()
Dim dwLen As Long
Dim
strString As String
  'Create a buffer
dwLen = MAX_COMPUTERNAME_LENGTH + 1
  strString = String(dwLen,
"X")
  'Get the computer name
  GetComputerName strString,
dwLen
  'get only the actual data
  strString = Left(strString,
dwLen)
  'Show the computer name
  Label1.Caption =
strString
End Sub
Joe ...
If one is using a
href="http://www.caddzone.com">
size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2009
through 2009
size=2>http://www.acadxtabs.com
size=2>Introducing AcadXTabs 2010:
href="http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm">
size=2>http://www.caddzone.com/acadxtab...
face=Arial size=2>"Kerry Brown" <
face=Arial size=2>kwb@home
> wrote in
message
face=Arial size=2>news:[email protected]
face=Arial size=2>...
href="http://discussion.autodesk.com/forums/ann.jspa?annID=125">
size=2>http://discussion.autodesk....
face=Arial size=2>  "plamp" wrote in message
href="news:[email protected]">
size=2>...
AutoCAD API for a
added an entity to
represents a new
1002, value: {
displayed in
tr
Message 5 of 19
Oh, and I use Outlook Express ...
Option Explicit
31
Long
Dim dwLen As
Long
Dim strString As String
  'Create a
buffer
  strString =
String(dwLen, "X")
  GetComputerName
strString, dwLen
  strString =
Left(strString, dwLen)
Label1.Caption = strString
End Sub
Joe ...
If one is using a
Supporting AutoCAD
2000 through 2009
face=Arial size=2>http://www.acadxtabs.com
size=2>http://www.caddzone.com/acad...
> wrote in
message
face=Arial
size=2>http://di...
size=2>...
AutoCAD API for a
added an entity to
represents a new
added as a
entities, but
a selection
{code}
Entity =
tr
Catch
End If
work. In most
make a difference:
Message 6 of 19
That's nice Steve.
"Joe Sutphin" wrote in message
Option Explicit
Private Const MAX_COMPUTERNAME_LENGTH As Long = 31
"GetComputerNameA" (ByVal lpBuffer As String, nSize As Long) As Long
Dim dwLen As Long
'Create a buffer
strString = String(dwLen, "X")
GetComputerName strString, dwLen
strString = Left(strString, dwLen)
End Sub
Joe ...
"Tony Tanzillo" wrote in message
to
{code}
Catch
If
most
What
Message 7 of 19
Now who's the doorknob?
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 8 of 19
Steve - you will always be the doorknob here.
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 9 of 19
Nope, sorry, you're mistaken again.
You were and will always be the doorknob.
I was just curious if you had realized it yet, but I see you haven't.
And stop calling me Steve, whoever that is!
Joe ...
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 10 of 19
Steve - Everyone that reads this newsgroup already
knows who the resident bottom-feeder is.
There's no need to point the finger .
Joe ...
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 11 of 19
So stop pointing it at yourself.
Joe ...
Joe ...
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 12 of 19
Steve - Perhaps you should find another place to display the resentment you
have for your own incompetence.
If you think others can't see your childish behavior for exactly what it is,
guess again.
Joe ...
Joe ...
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 13 of 19
If you think others have anything but contempt for you, you are sorely
mistaken.
You should stop your obviously misguided rant before you do anything else to
tarnish your already reprensible reputation.
Your insistance on being childish is quickly becoming your greatest asset.
Joe ...
guess again.
Joe ...
Joe ...
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 14 of 19
>>mistaken.
2 months ago you hadn't even debugged a .net application yet - I'll point
out the post if you like. Tony has been helping us all here for years. Go
away steve.
"Joe Sutphin" wrote in message news:[email protected]...
mistaken.
Joe ...
guess again.
Joe ...
Joe ...
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 15 of 19
Hey Steve,
Next time you see Joe, tell him to replace "reprensible" by "reprehensible".
That's important for Joe, since he's also pretending to be a writer of books
on AutoCAD VBA.
There's nothing "reprensible" about T. Tanzillo's reputation.
The man has little patience with oafs. But that's not "reprensible".
So Steve, get thee hence, and stop waisting our time.
Greetings
mistaken.
Joe ...
guess again.
Joe ...
Joe ...
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 16 of 19
Or is it "wasting"?
Really don't know...
"Guido Rooms" wrote in message news:[email protected]...
Hey Steve,
on AutoCAD VBA.
Greetings
mistaken.
Joe ...
guess again.
Joe ...
Joe ...
Joe ...
That's nice Steve.
Option Explicit
Dim dwLen As Long
'Create a buffer
End Sub
Joe ...
to
{code}
Catch
If
most
What
Message 17 of 19
{quote}
{quote}
I already tarnished my reptutation by having a conversation with you.
Message 18 of 19
If it helps you move on, you're welcome.
Joe ...
{quote}
{quote}
Message 19 of 19
... so are there any comments directed at the real content of my post?
I mean: the codesample shóuld in theory work, right? or did I miss something...
