Select all in model space
gwhitcherQ98HZ
Message 1 of 12
gwhitcherQ98HZ
How do I select all without a filter and iterate through all that has been selected in VB.Net?
Using this code generate an error at the ed.SelectAll() line
Try
Dim Res As PromptSelectionResult = ed.SelectAll()
If (Res.Status = PromptStatus.OK) Then
Dim selectedIds As ObjectId() = Res.Value.GetObjectIds()
Using lk As DocumentLock = doc.LockDocument()
Using tr As Transaction = db.TransactionManager.StartTransaction()
For j = 0 To selectedIds.Count - 1
Dim ent As Entity = DirectCast(GetObjectbyID(selectedIds(j)), Entity)
ent.UpgradeOpen()
ent.ColorIndex = 8
ent.DowngradeOpen()
Next
tr.Commit()
End Using
End Using
Catch ex As Exception
End Try
Replies (11)
Message 2 of 12
kerry_w_brown
What is the error message ?
Is it getting caught by in the catch block ?
Please use the '</>' button to post /format code
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 3 of 12
gwhitcherQ98HZ
yes. the error says: eNotApplicable
Message 4 of 12
kerry_w_brown
Are you calling this code from a form. ?
Is the document in a side database ?
is CommandFlags.Session added to your  CommandMethod attribute ?
( Editor interactive methods (ed.Getxxx, ed.Selectxxx, etc) can only be called on the active document )
Message 5 of 12
Ed__Jobe
Hi @kerry_w_brown
You can refer users to this sticky post.
Ed
How to post your code.
Message 6 of 12
gwhitcherQ98HZ
I just found out that issue. I wasn't setting the editor to the newly opened drawing. I am trying to change every entity to a specific color. I am at another error now.
Message 7 of 12
kerry_w_brown
@Ed__Jobe ,
Thanks Ed, I'll bookmark that.
I actually have one saved for C# code , but was in a hurry.
It also helps if the code is preformatted properly, but that's another issue 😉
Message 8 of 12
kerry_w_brown
@gwhitcherQ98HZ
good,
I assumed it would be an active document issue.
Message 9 of 12
gwhitcherQ98HZ
Once I have the objectIds, I get each one as a DBObject .  I have opened each one Forwrite but I get an einvalidopenstate error
Message 10 of 12
ActivistInvestor
What is the exception that is thrown by the call to SelectAll()?
If you are trying to select all objects in model space, there really isn't any point to calling SelectAll() when you can simply get the model space BlockTableRecord and enumerate its elements. There are hundreds of code examples posted here that demonstrate how to do that.
Message 11 of 12
gwhitcherQ98HZ
I found the problem. I was not resetting the database or the editor when I opened a new drawing
Message 12 of 12
kerry_w_brown
@gwhitcherQ98HZ ,
Aside from Tony's excellent point  . . .
The main thing to learn from this thread is to provide a good description of the problem conditions and to provide sufficient (readable and pre-formatted) code to allow deciphering the problem.
