Select a Text from AutoCAD and to Display in C# windows forms
Message 1 of 9
Dear All,
Season greetings to all experts,
with respect to above subject,
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Interop;
privatevoid button2_Click(object sender, EventArgse)
AcadApplication AcadApp = new Autodesk.AutoCAD.Interop.AcadApplication();
AcadDocument doc1 = AcadApp.Documents.Open("c:\\test.dwg");
AcadApp.Visible =true;
AcadApp.ZoomExtents();
double[] startPoint = newdouble[3];
double[] endPoint = newdouble[3];
startPoint[0] = 0; startPoint[1] = 0; startPoint[2] = 0;
endPoint[0] = 20; endPoint[1] = 20; endPoint[2] = 0;
AcadSelectionSet ssetObj = AcadApp.ActiveDocument.SelectionSets.Add("ss1");
ssetObj.Select(Autodesk.AutoCAD.Interop.Common.
AcSelect.acSelectionSetCrossingPolygon,startPoint,endPoint,Type.Missing, Type.Missing);
the idea is to select the AutoCAD text by crossingPolygon and then to display the selected text in the C# windows form label1.text.
Could you please help for this above request.
Thanks in Advance.
regards,
Micky.
Replies (8)
Message 2 of 9
Balaji_Ram
Hi Micky,
Greetings to you too 🙂
Will a pure .Net API route suit your needs ? You will not need the COM API for this :
Here is a sample code :
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.MessageForAdding = "\nSelect the entities";
            pso.SingleOnly = false;
            PromptSelectionResult psr = ed.GetSelection(pso);
            if (psr.Status != PromptStatus.OK) return;
            SelectionSet ss = psr.Value;
            foreach (SelectedObject selectedObj in ss)
                switch (selectedObj.SelectionMethod)
                    case SelectionMethod.Crossing:
                        CrossingOrWindowSelectedObject crossingWindSelectedObj = selectedObj as CrossingOrWindowSelectedObject;
                        break;
 The SelectionMethod enum has other values for Window selection and so on. You can check it out yourself.
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 9
norman.yuan
The OP is obviously doing a stand-alone EXE app that automate AutoCAD (or the OP would not have to have code "new AcadApplication();" , thus cannot use .NET API.
To OP:
In your Select() method, you only pass in 2 points, which cannot form a polygon, thus, the first argument of the Select() method should be acSelectionSetFence.
Since your selecting target is text, it would be better to supply a selection filter (the last 2 arguments of the Select() method).
Anyway, assume the Select() method does return a set of AcadEnity, you simply loop through the SelectionSet to retrieve test string, like this:
StringBuillder txt=new StringBuilder();
foreach (object ent in ssetObj)
    AcadText t=ent as AcadText
    if (T!=null)
        txt.Append(t.TextString + "\n");
//Show the text clollected in message box, or in your form.
MessageBox.Show(t.ToString());
Of course, if your selection target alos include MText, then you need to deal with it accordingly.
Norman Yuan
Drive CAD With Code
Message 4 of 9
Dear Mr.Balaji,
Season Greetings,
Thanks for your quick response,
I am a beginer for .Net C#, that's why I am struggling a bit.
In my codings I have some error in crossingpolygon selection method, rest everything working well.
I am in need of 2 things,
1. select a Text from AutoCAD by crossingpolygon method,
2. store it in a string varible to display in C# windows forms.
Could you please help me for this above request,
I am trying hard to learn this .Net, I have a big hope that as soon as possible i will be getting a clear understanding of .net.
Thanks & regards,
Micky.
Message 5 of 9
Hallex
If you're using Interop better yet to define variables explicitly
before you will be pulling them to the method / function
From other hand you confused the selection mode
try this code snip instead and tell us about result after 🙂
{code}
object miss = Type.Missing;
Autodesk.AutoCAD.Interop.Common.AcSelect mode = AcSelect.acSelectionSetCrossing;
ssetObj.Select(mode, startPoint, endPoint, miss, miss);
MessageBox.Show(ssetObj.Count.ToString());{code}
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 6 of 9
Dear Mr. Norman,
Season Greetings,
thanks for your response,
for crossingpolygon selection method I using bottom left corner and top right corner only,
Could you please see my reply post to Mr. Balaji, that's my problem and I got struck.
Thanks & regards,
Micky.
Message 7 of 9
norman.yuan
OK, simply call
ssetobj.Select(acSelectionSetWindow, startPoint, endPoint,....)
Norman Yuan
Drive CAD With Code
Message 8 of 9
chiefbraincloud
or rather acSelectionSetCrossing, but not acSelectionSetCrossingPolygon.
Message 9 of 9
Dear Mr. Hallex,
Thanks very much for your kindness & support, the code is working well.
where I will get reference or help file for the all the methods?
for examples :
[object filter Type = Type.missing] --- where to find examples or help files?
[object filter Data = Type.missing]--- where to find examples or help files?
for examples :
AcadDocument doc1 = acApp.Documents.Open(textBox1.Text);
In open method,
I have given only the file name, if I wnat to give other two inputs then how?
so where I will get reference or help files for all the methods.
best regards,
Micky.
