Scalling drawing with transformBy
natuanmdc
natuanmdc
Hi everyone
I'm trying to scalling my drawing which combined by 2D entities et 3D entities (3d points), if i use command
acEnt.TransformBy(Matrix3d.Scaling(param_k,Point3d.Origin));
it will change the Z valeur of these 3D entities.
Do you have a solution for this problem please?
Thanks a lots
Alexander.Rivilis
In order to preserve Z-coordinate you have to move entity after scaling.
Other way is pass instead of Point3d.Origin other point, which will not affected with scaling.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
natuanmdc
Thank you for your answer but when the drawing was changed the scale of Z with the factor, there is no constant to move the drawing to the Z origin value.
