Save BlockReference to separate file
denisyukJ
Message 1 of 8
denisyukJ
I have several blocks (BlockReference) in model space and I would like to save them separatly exactly like _WBLOCK command does. I've tried to play around Wblock() method of DB class, but no luck. Maybe I fed a wrong id to it or I simply dont understand how method works.
Any help or hint will be highly appreciated.
BR, Evgeniy
Replies (7)
Message 2 of 8
ActivistInvestor
BR, Evgeniy
Most participants here will not endeavour to guess why your code may be not be working.
Post the code so that others can look at it and tell you what it is doing wrong.
Message 3 of 8
denisyukJ
Hi, @ActivistInvestor
This peace of code saves block in separate file but as block reference already existing in modele space so I can not use directory includes this block as library. _WBLOCK command saves a block as block definition.
        static public void WblockEntity()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptSelectionResult prRes = ed.GetSelection();
            if (prRes.Status != PromptStatus.OK)
                return;
            ObjectIdCollection objIds = new ObjectIdCollection();
            ObjectId[] objIdArray = prRes.Value.GetObjectIds();
            // Copy objectIds to objectIdCollection
            foreach (ObjectId id in objIdArray)
                objIds.Add(id);
            using (Database newDb = new Database(true, false))
                db.Wblock(newDb, objIds, Point3d.Origin, DuplicateRecordCloning.Ignore);
                string FileName = "C:\\Users\\User\\OneDrive\\Desktop\\wblock.dwg";
                newDb.SaveAs(FileName, DwgVersion.Newest);
Message 4 of 8
ActivistInvestor
Unfortunately, the docs for WBlock() are deficient, and do not go into detail on the 4 overloaded versions of that method. They only show the declarations for each and describe what one of the overloads does.
You need to use the overload of Wblock() that takes a single ObjectId as an argument, and returns a new Database (that you must dispose of when finished with it):
public Database Wblock(ObjectId blockTableRecordId)
You pass the ObjectId of the BlockTableRecord for the block that you want to write to the new Database.
Message 5 of 8
denisyukJ
@ActivistInvestor,
Thank you, I've made 2 options:
>> 1st option uses Wblock(ObjectId id) as you suggest;
>> 2nd option uses Wblock(ObjectIdCollection col, Point3d pt)
Unfortunately, both of them led me to the same result -- new file is empty.
Here's code:
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable acBlkTbl = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                if (acBlkTbl.Has("054010V"))
                    var blkTblRecId = acBlkTbl["054010V"];
                        db.Wblock(blkTblRecId);
                        string fileName = "C:\\Users\\User\\OneDrive\\Desktop\\wblock.dwg";
                        newDb.SaveAs(fileName, DwgVersion.Newest);
                tr.Commit();
 public void WblockEntity() // ObjectId of the BlockTableRecord for the block
             var blkTblRec = tr.GetObject(blkTblRecId, OpenMode.ForRead) as BlockTableRecord;
             foreach (var ObjId in blkTblRec)
                 objIds.Add((ObjectId)ObjId);
                 db.Wblock(objIds, new Point3d(0, 0, 0));
         tr.Commit();
Message 6 of 8
ActivistInvestor
Look again at the the declaration for the Wblock(ObjectId) method overload I showed in my previous reply.
What does it return?
Message 7 of 8
denisyukJ
Looks like this code is working 😀 Thank you @ActivistInvestor
            Database newDb = new Database(true, false);
            newDb = db.Wblock(blkTblRecId);
        tr.Commit();
Message 8 of 8
norman.yuan
While you got the block definition saved as block drawing, this portion of code is still problematic:
Firstly, you DO NOT create a Database instance, and then only leave/lose it in memory. Secondly, the Database instance created by db.WBlock() also needs to be disposed, as @ActivistInvestor clearly suggested. So the code should be:
            using (var newDb = db.Wblock(blkTblRecId))
Norman Yuan
Drive CAD With Code
