Running a program freezes my layout tabs
GeeHaa
GeeHaa
Hi
I wrote a small auto numbering program that works fine only it freezes the layout tabs every time it is run. Hitting regen gets them back, Has anyone else run into this? I am running AutoCAD 2010. The program was written in VB.Net express 2008.
StephenPreston
Not a problem I've seen before. Hard to say what you did wrong without seeing any code.
Cheers,
Stephen Preston
Autodesk Developer Network
Cheers,
Stephen Preston
Can you post your code?
GeeHaa
Sorry I couldn't post my code. I feltl I would have to post the whole project. But I found the answer. I was using Form1.showdialog to show the form. If I use Application.showmodaldialog(form1) it doesn't freeze the layout tabs.
That's correct. You should being using the Autocad application.show..... Dialogs.
They are the correct method for displaying forms. Way to go!
