Rider and .NET 6 target framework
contactSAPDT
Observer Observer
Message 1 of 8
contactSAPDT
Observer
Observer
Dear community, I have installed Rider and went through the tutorial. At the step named Set the Target Framework, it suggests to select .NET Framework 4.8. However, Rider suggests net6.0 - would it be safe to use that instead, or is it incompatible?
Also, using the net6.0 target and the code from the tutorial, the build process yields a few warnings:
Please advise. -- Many thanks, Anton
Replies (7)
Message 2 of 8
_gile
The AutoCAD .NET API requires to target the .NET Framework. It does not support Net 6.0.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
norman.yuan
I assume you are talking about using Rider, an .NET IDE, instead of Visual Studio for AutoCAD .NET API/Plugin development. While I have no experience of using Rider (or anything else than VS), it is CERTAIN that you MUST ONLY USE .NET Framework (4.7 or 4.8 for later versions of AutoCAD), and CANNOT use .NET core (.NET 5, 6, or upcoming 7), regardless whatever Rider suggests.
BTW, the last version of .NET Framework is 4.8. There nothing called "Framework" since .NET 5.
Norman Yuan
Drive CAD With Code
Message 4 of 8
contactSAPDT
Observer
Observer
So, this means the target must be set to .NET Framework 4.7.1, and the language version that can be used is C# 7.3? Also, since you said 4.8, does it mean .NET Framework 4.8.1 would also work with the latest version of AutoCAD?
Message 5 of 8
norman.yuan
I would always using .NET Framewrok 4.8x for latest AutoCAD versions (say, after Acad2019), the C# version is determined by the .NET Framework. Yes, it sucks for not being able to take advantage of fancy features added to C# in later versions, only available with .NET Core (.NET 5, 6...), especially if one also does .NET core programming.
Norman Yuan
Drive CAD With Code
Message 6 of 8
cesar_mayorine362SG
all this means that we are sitting on a time bomb?
Framework 4.8 is no longer supported by Microsoft.
Message 7 of 8
_gile
AutoCAD 2025 will support .NET 8.0
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
ActivistInvestor
Actually, it is possible to use newer versions of C# with older framework versions, with some caveats, and I do that now when necessary.
You can have a look at the following discussions about it and also guidance on how to change the language version in a project.
https://stackoverflow.com/questions/56651472/does-c-sharp-8-support-the-net-framework/57020770#57020...
https://sergiopedri.medium.com/enabling-and-using-c-9-features-on-older-and-unsupported-runtimes-ce3...
