Error message
Error message
k005
Advisor Advisor
Message 1 of 18
Error message
k005
Hello everyone
How can I get the error message when the command does not work in the below line of code?
Thank you.
 private void btnYap_Click(object sender, EventArgs e)
            this.Hide();
            Adoc.SendStringToExecute("elev1_symbol\n", true, false, true);
            this.Close();
Replies (17)
Message 2 of 18
_gile
See this topic.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 18
k005
Hi
I added the try-catch structure before posting on the forum. I also put a message box.
It didn't show the message when I tested it.
Message 4 of 18
k005
@_gile
elev1_symbol
this is a lisp command. It works from within the lisp routine.
I don't know if it makes a difference... in this case, how should the example try catch structure be?
Thank you.
Message 5 of 18
_gile
Is there any error message in the AutoCAD command line/text screen?
Gilles Chanteau
GileCAD
GitHub
Message 6 of 18
hippe013
(defun myLispFoo ()
  (princ "\nHello World")
  (princ)
aDoc.SendStringToExecute("(myLispFoo) ", True, False, True)
Notice the parentheses before and after function name and then a space after that.
Message 7 of 18
k005
command line message: Unknown command "elev1_symbol". Press F1 for help.
The classic answer of autocad. In fact, it is clear from this message. but I will specify the lisp name with the
messagebox...
Message 8 of 18
k005
i did it this way. but I didn't get the message.
 private void btnOfsetAt_Click(object sender, EventArgs e)
            this.Hide();
            try
                Adoc.SendStringToExecute("(elev1_symbol) ", true, false, true);
            catch (Exception)
                //throw;
                MessageBox.Show("abcdef lispi yüklü değil.");
            this.Close();
Message 9 of 18
hippe013
Were you expecting an error?
Message 10 of 18
k005
Yes. As I mentioned in my question.
so the elev1_symbol command is not available... so I should get an error.
Message 11 of 18
hippe013
(defun c:myLispCmd ()
  (princ "\nHello Command!")
  (princ)
aDoc.SendStringToExecute("(c:myLispCmd) ", True, False, True)
(defun myLispFoo ()
  (princ "\nHello Function!")
  (princ)
Message 12 of 18
hippe013
An error in the execution of the lisp will not bubble up to be an error in the execution of the .NET portion of your code. The try catch will catch errors in your SendStringToExecute and not an error within the lisp itself. That is my understanding anyways.
Message 13 of 18
k005
I understand.
I cannot use the try catch construct for this situation.
Thank you.
Message 14 of 18
hippe013
If you are trying to catch the error within your lisp, use the *error* definition to catch the error. I was showing how send the lisp using the SendStringToExcecute method. What did you want the Try-Catch to catch?
Message 15 of 18
k005
now on this i'm not talking about coding an error message in lisp.
only lisp relation should be in button click event. which, if lisp already exists, the command works. If not, it gives an
error on the command line. not found etc...
I wanted to receive the not found message with the message box.
Message 16 of 18
hippe013
How about creating a .NET lisp function that checks for the existence of the defined lisp command and returns a boolean?
Message 17 of 18
norman.yuan
If you are using SendStringToExecute(), regardless of the code being executed is LISP command or .NET command, there is no use to wrap it with try...catch..., because the SendStringToExecute() is async and only runs AFTER the calling routine ends (in your case, the execution runs through the try...catch... and the button click routine is done, then the action called in SendStringToExecute() starts). So even there is error because of the SendStringToExecute(), the error cannot be send back to the calling routine, because it HAS ALREADY ENDED.
Norman Yuan
Drive CAD With Code
Message 18 of 18
k005
Many thanks for the detailed explanation.
I'm closing the issue.
