RibbonSplitButton Synchronized With Current Item and Static text?
andgas.lordone
andgas.lordone
I'm a little problem with the RibbonSplitButton.
I wanted the current button contains the image and the action of current item, but the text I want it to be static.
The RibbonSplitButton contains a property called "IsSynchronizedWithCurrentItem" that does this, but it takes all information of current item.
I want behavior equal to the circle of ribbon autocad, where the text "circle" is static, as shown in the image below:
Below a generic code of how I did:
RibbonSplitButton panSplitButton = new RibbonSplitButton();
panSplitButton.Text = "Circle";
panSplitButton.ShowText = true;
panSplitButton.ShowImage = true;
panSplitButton.IsSplit = true;
panSplitButton.Size = RibbonItemSize.Large;
panSplitButton.IsSynchronizedWithCurrentItem = true;
RibbonButton panButton1 = new RibbonButton();
panButton1.Text = "Center, Radius";
panButton1.ShowText = true;
panButton1.ShowImage = true;
panButton1.Image = Images.getBitmap(Properties.Resources.Small);
panButton1.LargeImage = Images.getBitmap(Properties.Resources.large);
panButton1.Size = RibbonItemSize.Large;
panButton1.Orientation = System.Windows.Controls.Orientation.Vertical;
panButton1.CommandHandler = new RibbonCommandHandler();
RibbonButton panButton2 = new RibbonButton();
panButton2.Text = "Center, Diameter";
panButton2.ShowText = true;
panButton2.ShowImage = true;
panButton2.Image = Images.getBitmap(Properties.Resources.Small);
panButton2.LargeImage = Images.getBitmap(Properties.Resources.large);
panButton2.Size = RibbonItemSize.Large;
panButton2.Orientation = System.Windows.Controls.Orientation.Vertical;
panButton2.CommandHandler = new RibbonCommandHandler();
panSplitButton.Items.Add(panButton1);
panSplitButton.Items.Add(panButton2);
How can I keep the static text "circle" in the "IsSynchronizedWithCurrentItem" property as true?
Jeff_M
Welcome to the Forums!
Use the SynchronizeOption property:
panSplitButton.SynchronizeOption = RibbonListButton.RibbonListButtonSynchronizeOption.Image;
andgas.lordone
Thank you, your answer worked here! Thank you so much!
I think that this property "SynchronizeOption" should be specified in the documentation of autodesk, on Managed Class Reference Guide.
