Ribbon Elements sample code and reproducing
1479892004
1479892004
Community Visitor
Community Visitor
I  am tring  to reproduce the sample code in
 Customize User Interface (CUI) Managed API (.NET)  at Ribbon Elements (.NET)
,But  some prblom like
CODE 1:
RibbonButton button1 = new RibbonButton();//RibbonButton in Autodesk.Windows   (adwindows.dll)
button1.text = “button1”;//I have no  see  the string property in the RibbonButton class
CODE 2:
RibbonRow row = new RibbonRow();//RibbonRow not in Autodesk.Windows (adwindows.dll)
row.RowItems.Add(button1);// If use Autodesk.AutoCAD.Customization namespace(may be in acui.dll)
row.RowItems.Add(button2);//not have the property call “RowItems”
CODE 3:
RibbonPanelSource panelSource = new RibbonPanelSource();
panelSource.Title = "Panel1";
panelSource.Rows.Add(row);//not have the property call “Row”
The developer’s document writed the Ribbon Element ‘s interface in Autodesk.Windows(adwindows.dll)
How to solve it?
thank you
CODE 在上面贴出了,不知道为什么复现不了样例代码。
RibbonButton类我也没看懂这个Text属性哪里来的,
RibbonRow类也不在Autodesk.Windows 命名空间里面,
RibbonPanelSource的类内部属性也没有Row这个属性。
非常感谢解答!
Norman_Yuan
There are 2 sets of ribbon related APIS: one is in Autodesk.AutoCAD.Customiztion namespace of the assembly acCui.dll, the other is in Autodesk.Windows namespace of the assembly adWindows.dll.
When you say you try to "reproduce the sample code...", you need to know which set of API the sample code uses.
Norman Yuan
Drive CAD With Code
Community Visitor
Community Visitor
Thank you very much for your reminding!
I tried to improve the sample code to run under the Autodesk.Windows namespace of Adwindows.dll.
I replaced the old class RibbonRow with the RibbonRowPanel class. I tried to initialize the ribbon element, but it didn't work.
There are no warning and compile fails
CODE:
using Autodesk.Windows;
public class adskClass : IExtensionApplication
       public void Initialize()
            Text = "Button1"
            RibbonButton button2 = new RibbonButton
            Text = "Button2"
            RibbonRowPanel E = new RibbonRowPanel
            Items = {button1, button2}
            Title = "Panel1"
            panelSource.Items.Add(E);
            RibbonPanel panel = new RibbonPanel
            Source = panelSource
            RibbonTab tab = new RibbonTab
            Title = "Tab1"
            tab.Panels.Add(panel);
            RibbonControl ribbon = new RibbonControl();
            ribbon.Tabs.Add(tab);
What should I do to add Ribbon ?
非常感谢您的提醒
我尝试改进了示例代码使之能够在Adwindows.dll 的 Autodesk.Windows 命名空间下运行。
我用RibbonRowPanel类 替换了原来的老 class RibbonRow。我尝试初始化加载此ribbon element ,但是没有正常工作。
我应该怎么做才能正常的添加Ribbon?
Norman_Yuan
OK, it looks like you want to create a custom ribbon tab with code and loaded when your DLL is loaded.
This topic has been discussed here many times. Please search this forum for "Ribbon", you will find quite a few past discussion threads with code in them, such as:
https://forums.autodesk.com/t5/net/custom-menu-and-ribbon-with-code/m-p/10511529
https://forums.autodesk.com/t5/net/net-c-ribbon-tab/m-p/3920030
https://forums.autodesk.com/t5/net/ribbon-not-loading-on-autocad-2024/m-p/12130528
Norman Yuan
Drive CAD With Code
