My main goal is to add an attribute to all blocks named 8x11General found in a drawing. I found a way to do it using doc.Editor to add the new attribute definition, but this way of doing is not optimal for me, since eventually I will need to run this code on all drawing found within a folder and it would oblige me to open each one of them.
So I'm wondering if there is a way to add an attribute to a block definition using only the doc.Database or anything else that would not require the use of the doc.Editor (which requires the opening of the dwg file).
Thank you in advance for your time.
My current code that adds an attribute using the doc.Editor:
private readonly List<string> _blocksToProcess = new List<string> { "8x11General"};
[CommandMethod("AddAttribute")]
public void AddAttributeToBlocks()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction tr = db.TransactionManager.StartTransaction())
var filter = new SelectionFilter(new[]
new TypedValue((int)DxfCode.Start, "INSERT")
PromptSelectionResult psr = ed.SelectAll(filter);
if (psr.Status != PromptStatus.OK)
return;
foreach (SelectedObject so in psr.Value)
var br = (BlockReference)tr.GetObject(so.ObjectId, OpenMode.ForWrite);
if (_blocksToProcess.Contains(br.Name))
AddAttributeToBlock(br, db, tr);
else
// Add code here to check for nested blocks and add attributes
ProcessNestedBlocks(br, db, tr);
tr.Commit();
private void AddAttributeToBlock(BlockReference br, Database db, Transaction tr)
br.Highlight();
// Get the block's insertion point
Point3d blockInsertionPoint = br.Position;
// Calculate the top-right corner of the block
Point3d p = blockInsertionPoint + new Vector3d((br.GeometricExtents.MaxPoint.X + br.GeometricExtents.MinPoint.X) / 2,
(br.GeometricExtents.MaxPoint.Y + br.GeometricExtents.MinPoint.Y) / 2,
0);
var attRef = new AttributeReference(p, "SHMURRR", "BOBBY", db.Textstyle)
Invisible = true, //Make the attribute invisible
LockPositionInBlock = false,
br.AttributeCollection.AppendAttribute(attRef);
tr.AddNewlyCreatedDBObject(attRef, true);
db.TransactionManager.QueueForGraphicsFlush();
br.Unhighlight();
private void ProcessNestedBlocks(BlockReference br, Database db, Transaction tr)
// Retrieve the block table record of the current block
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForRead);
foreach (ObjectId objectId in btr)
if (objectId.ObjectClass == RXClass.GetClass(typeof(BlockReference)))
var nestedBlock = (BlockReference)tr.GetObject(objectId, OpenMode.ForWrite);
if (_blocksToProcess.Contains(nestedBlock.Name))
AddAttributeToBlock(nestedBlock, db, tr);
else
// Recursively check for nested blocks
ProcessNestedBlocks(nestedBlock, db, tr);
