Revision Cloud
Revision Cloud
SRSDS
Advisor Advisor
Revision Cloud
SRSDS
I want to cloud a polyline.
This works :
    <CommandMethod("RevisionCloud")>
    Public Shared Sub RevisionCloud()
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
        Dim ids As List(Of ObjectId) = New List(Of ObjectId)()
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim bt As BlockTable = TryCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
            Dim ms As BlockTableRecord = TryCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
            Using c As Circle = New Circle(New Point3d(0, 0, 0), Vector3d.ZAxis, 20)
                Dim circleId As ObjectId = ms.AppendEntity(c)
                tr.AddNewlyCreatedDBObject(c, True)
                ids.Add(circleId)
            End Using
            tr.Commit()
        End Using
        Dim ss As SelectionSet = SelectionSet.FromObjectIds(ids.ToArray)
        ed.Command("_.REVCLOUD", "", "O", "", ss, "")
    End Sub
but when I try to implement it I get
Autodesk.AutoCAD.Runtime.Exception: 'eInvalidInput'
on the line ed.Command("_.REVCLOUD", "", "O", "", ss, "")
I can't work out out what the problem might be.
Alternatively, does anyone have code that will cloud a polyline from a set of vertices?
_gile
You should pass the circle ObjectId to the command instead of a selection set.
[CommandMethod("REVISIONCLOUD")]
public static void RevisionCloud()
    var doc = Application.DocumentManager.MdiActiveDocument;
    var db = doc.Database;
    var ed = doc.Editor;
    ObjectId circleId;
    using (var tr = db.TransactionManager.StartTransaction())
        var modelSpace = (BlockTableRecord)tr.GetObject(
            SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
        var circle = new Circle(Point3d.Origin, Vector3d.ZAxis, 20.0);
        circleId = modelSpace.AppendEntity(circle);
        tr.AddNewlyCreatedDBObject(circle, true);
        tr.Commit();
    ed.Command("_.REVCLOUD", "_Object", circleId, "_No");
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
SRSDS
Hi Gile,
Both those work but your's is better as calling ed.Command("_.REVCLOUD", "", "O", "", ss, "")
on a SelectionSet doesn't work too well as the "_.REVCLOUD" command only handles one entity at a time. ie only clouds one of the entities in the ss.
I still seem to have a problem with applying it in my project which has me utterly confused.
I still get a Autodesk.AutoCAD.Runtime.Exception: 'eInvalidInput'  on the line
The only difference I can think of is that code is being triggered by modifying a textbox control in a pallete.
Not sure if this makes sense but I tried getting the objects handle when it was created then converting it back to an objectID before the editor command to make sure it was the same entity. Grasping at straws but that checked out.
_gile
If you call this method from a Palette (i.e. in application context) you should call it using:
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("REVISIONCLOUD ", false, false, false);
so that you let AutoCAD switch to document context and lock the document.
Gilles Chanteau
GileCAD
GitHub
SRSDS
Thank you again.
