reverse command with parameter
I need to use autocad reverse command in c# .net with a polyline as a parameter.
I used http://www.caddzone.com/CommandLine.cs without success getting InvalidOperationException.
How can I do?
Are you expecting someone to guess what your
code is doing that may be causing the error?
Sorry,
I use:
public void FirstCheck()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            Transaction tr = db.TransactionManager.StartTransaction();
            LayerTable acLyrTbl = tr.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
            BlockTable bt = (BlockTable)tr.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId, OpenMode.ForRead);
            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(HostApplicationServices.WorkingDatabase.CurrentSpaceId, OpenMode.ForWrite);
            using (tr)
                foreach (ObjectId asObjId in btr)
                    DBObject obj = tr.GetObject(asObjId, OpenMode.ForRead);
                    Entity ent = obj as Entity;
                    if (asObjId.ObjectClass.DxfName.CompareTo("LWPOLYLINE") == 0)
                        Polyline lwp = obj as Polyline;
                        decimal Area = (decimal)PlineAlgebraicArea(lwp);
                        if (Area > 0)
                            CommandLine.Reverse(lwp);
                tr.Commit();
where CommandLine is http://www.caddzone.com/CommandLine.cs with added:
  public static int Reverse(Polyline lwp)
            return Command("_REVERSE ", lwp);
That's better.
Before you run commands on objects, you should commit
the transaction you got them from.
In the version of CommandLine.cs that you have, DBObjects
cannot be passed to Command(), only their ObjectIds can be
passed.  A new version of CommandLine.cs is in the works
that supports passing an Entity or its ObjectId, but that's not
ready yet.
So, after you commit the transaction you get the polyline from,
you just pass its ObjectId to Command() rather than the Polyline
itself.
Also, i see you've added a Reverse() method to the CommandLine
class. While there's no problem with doing that, You don't really
have to, you can just calll Command() directly like this:
CommandLine.Command( "._REVERSE", asObjId, "" );
Lastly, you may be able to reverse a polyline without having
to use the command line. The PolyLine class has a ReverseCurve()
method (not sure what release that showed up in, so it may
not be in the releases you're targeting).
Many thanks!
