reusing the portion of a sub of a commandmethod in another..
10:50 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Imports System Imports System.Runtime.InteropServices Imports System.Drawing Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Namespace ACADProtection Public Class AutoCAD_RS_Commands Public Const Key_For_Protection_Class As String = "The protection class used" Public Const pi = Math.PI ' << one method here , set the value of radius , stored it in hashtable to be used in other commands >> <CommandMethod("sweep_a_cylinder")> Public Sub SweepAlongCylinder() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim ud As Hashtable = doc.UserData Dim rad As Double rad = ud(Key_For_Protection_Class) Using tr As Transaction = db.TransactionManager.StartTransaction() Dim ppo As PromptPointOptions = New PromptPointOptions(vbLf & "choose/click the centre of the base circle:") Dim ppr As PromptPointResult = doc.Editor.GetPoint(ppo) Dim pt As Point3d = ppr.Value If ppr.Status = PromptStatus.Cancel Then Exit Sub Dim pdo1 As PromptDoubleOptions = New PromptDoubleOptions(vbLf & "The radius of the cylinder? ") Dim pdr1 As PromptDoubleResult = doc.Editor.GetDouble(pdo1) Dim pd1 As Double = pdr1.Value If pdr1.Status = PromptStatus.Cancel Then Exit Sub Dim pdo2 As PromptDoubleOptions = New PromptDoubleOptions(vbLf & "The height of the cylinder? ") Dim pdr2 As PromptDoubleResult = doc.Editor.GetDouble(pdo2) Dim pd2 As Double = pdr2.Value If pdr2.Status = PromptStatus.Cancel Then Exit Sub 'setting the points to be passed to functions Dim pt1 As Point3d = New Point3d(pt.X + pd1, pt.Y, pt.Z) 'look in the picture Dim pt2 As Point3d = New Point3d(pt.X + pd1, pt.Y, pt.Z + pd2) Dim pt4 As Point3d = New Point3d(pt.X, pt.Y, pt.Z + pd2) 'construct another circle on top Dim Cir2 As Circle = New Circle() Cir2.Center = pt4 Cir2.Normal = New Vector3d(0, 0, 1) Cir2.Radius = pd1 Dim spline_and_polyline3d As DBObjectCollection = getting_arc_polyline(pt1, pt2, rad) Dim spl1 As Arc = arc_and_polyline(0) Dim pl3d1 As Polyline = arc_and_polyline(1) Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead) Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite) btr.AppendEntity(spl1) tr.AddNewlyCreatedDBObject(spl1, False) 'can be removed?? btr.AppendEntity(pl3d1) tr.AddNewlyCreatedDBObject(pl3d1, False) 'can be removed?? pl3d1.JoinEntity(spl1) Dim curUCSMatrix As Matrix3d = ed.CurrentUserCoordinateSystem Dim curUCS As CoordinateSystem3d = curUCSMatrix.CoordinateSystem3d pl3d1.TransformBy(Matrix3d.Rotation(pi / 2, curUCS.Xaxis, pt1)) Dim ent As Entity Dim sob As SweepOptionsBuilder = New SweepOptionsBuilder Dim sol As Solid3d = New Solid3d sol.CreateSweptSolid(pl3d1, Cir2, sob.ToSweepOptions) ent = sol If rad = 20000 Then ent.ColorIndex = 1 ElseIf rad = 30000 Then ent.ColorIndex = 2 ElseIf rad = 45000 Then ent.ColorIndex = 3 ElseIf rad = 60000 Then ent.ColorIndex = 4 End If btr.AppendEntity(ent) tr.AddNewlyCreatedDBObject(ent, True) tr.Commit() End Using End Sub ' %%%%%%%%% another command %%%%%%%%%%%% <CommandMethod("sweep_a_cylinder_cutoff")> Public Sub SweepAlongCylinderWithCutoff() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim ud As Hashtable = doc.UserData Dim rad As Double rad = ud(Key_For_Protection_Class) Using tr As Transaction = db.TransactionManager.StartTransaction() Dim ppo As PromptPointOptions = New PromptPointOptions(vbLf & "choose/click the centre of the base circle:") Dim ppr As PromptPointResult = doc.Editor.GetPoint(ppo) Dim pt As Point3d = ppr.Value If ppr.Status = PromptStatus.Cancel Then Exit Sub Dim pdo1 As PromptDoubleOptions = New PromptDoubleOptions(vbLf & "The radius of the cylinder? ") Dim pdr1 As PromptDoubleResult = doc.Editor.GetDouble(pdo1) Dim pd1 As Double = pdr1.Value If pdr1.Status = PromptStatus.Cancel Then Exit Sub Dim pdo2 As PromptDoubleOptions = New PromptDoubleOptions(vbLf & "The height of the cylinder? ") Dim pdr2 As PromptDoubleResult = doc.Editor.GetDouble(pdo2) Dim pd2 As Double = pdr2.Value If pdr2.Status = PromptStatus.Cancel Then Exit Sub 'setting the points to be passed to functions Dim pt1 As Point3d = New Point3d(pt.X + pd1, pt.Y, pt.Z) 'look in the picture Dim pt2 As Point3d = New Point3d(pt.X + pd1, pt.Y, pt.Z + pd2) Dim pt4 As Point3d = New Point3d(pt.X, pt.Y, pt.Z + pd2) 'construct another circle on top Dim Cir2 As Circle = New Circle() Cir2.Center = pt4 Cir2.Normal = New Vector3d(0, 0, 1) Cir2.Radius = pd1 Dim spline_and_polyline3d As DBObjectCollection = getting_arc_polyline_cutoff(pt1, pt2, rad) Dim spl1 As Arc = arc_and_polyline(0) Dim pl3d1 As Polyline = arc_and_polyline(1) Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead) Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite) btr.AppendEntity(spl1) tr.AddNewlyCreatedDBObject(spl1, False) 'can be removed?? btr.AppendEntity(pl3d1) tr.AddNewlyCreatedDBObject(pl3d1, False) 'can be removed?? pl3d1.JoinEntity(spl1) Dim curUCSMatrix As Matrix3d = ed.CurrentUserCoordinateSystem Dim curUCS As CoordinateSystem3d = curUCSMatrix.CoordinateSystem3d pl3d1.TransformBy(Matrix3d.Rotation(pi / 2, curUCS.Xaxis, pt1)) Dim ent As Entity Dim sob As SweepOptionsBuilder = New SweepOptionsBuilder Dim sol As Solid3d = New Solid3d sol.CreateSweptSolid(pl3d1, Cir2, sob.ToSweepOptions) ent = sol If rad = 20000 Then ent.ColorIndex = 1 ElseIf rad = 30000 Then ent.ColorIndex = 2 ElseIf rad = 45000 Then ent.ColorIndex = 3 ElseIf rad = 60000 Then ent.ColorIndex = 4 End If btr.AppendEntity(ent) tr.AddNewlyCreatedDBObject(ent, True) tr.Commit() End Using End Sub ' getting_arc_polylinefunction is here ' getting_arc_polyline_cutoff end class end namespace
The above is my code written in VB.NET and I have a few questions.
(1). There are two very similar commands (one highlighted in Bold and another in italic). The only difference between them is that two different functions are called in the sub. Is there a way to reduce the redundancy because I feel it is rather pointless to write the same code twice.
(2). I have to set different colours for the resulting solid3d depending on the size of radius chosen. Can I also make it more efficient for I don't think writing it in all customized commands(there are as many as 20) is not a good programming practice?
Any kind of help and suggestion would be very much appreciated.
