Retrieve the Geometrical data from AutoCad Objects...
I've made some arx-programs for AutoCad 2002 so I'm not really new in this
topic. My first goal for my first ".NET-ARX" in C# is to traverse the
current document and retrieve all objects geometrical data, no matter which
type they are. Do you now any way of getting the geometrical data form the
objects in C#.
If you have any tip of where to expand my knowledge in ".NET-ARX" I'm really
grateful...
Here is some vb code that selects objects then filters out the text &
circles. It should give you an idea of how to get the data you are after
using C#
Public Sub GetAll()
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'Set the selection options
Dim SelOpts As New PromptSelectionOptions
SelOpts.MessageForAdding = "Select Objects:"
SelOpts.AllowDuplicates = True
'Make the selection:
Dim res As PromptSelectionResult = ed.GetSelection()
If Not res.Status = PromptStatus.OK Then Return
Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = res.Value
Dim idarray As ObjectId() = SS.GetObjectIds()
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager =
db.TransactionManager
'start a transaction
Dim myT As Transaction = tm.StartTransaction()
Try
Dim id As ObjectId
For Each id In idarray
Dim entity As Entity = tm.GetObject(id, OpenMode.ForRead, True)
If TypeOf entity Is Autodesk.AutoCAD.DatabaseServices.DBText Then
' DBTEXT Origin = bottom left
TextBox1.Text += "DBTEXT FOUND " & vbCrLf
Dim Txt As Autodesk.AutoCAD.DatabaseServices.DBText = entity
Dim k
TxtFound = TxtFound + 1
k = Txt.TextString
TextBox1.Text += "STRING " & k.ToString & vbCrLf
TextFnd(1, TxtFound) = k.tostring
k = Txt.Position
TextBox1.Text += "POSITION " & vbCrLf & k.ToString & vbCrLf & vbCrLf
Dim Spl
Spl = Mid(k.tostring, 2, Len(k.tostring) - 2)
TextBox1.Text += "SPLIT" & Spl & vbCrLf
Dim sa() As String
sa = Split(Spl, ",", -1)
TextFnd(0, TxtFound) = TxtFound
TextFnd(2, TxtFound) = sa(0)
TextFnd(3, TxtFound) = sa(1)
End If
If TypeOf entity Is Autodesk.AutoCAD.DatabaseServices.MText Then
TextBox1.Text += "*MTEXT FOUND " & vbCrLf
Dim Txt As Autodesk.AutoCAD.DatabaseServices.MText = entity
Dim k
'k = Txt.Id
'TextBox1.Text += "ID " & k.ToString & vbCrLf
k = Txt.Contents
TextBox1.Text += "Contents " & k.ToString & vbCrLf & vbCrLf
k = Txt.Location
TextBox1.Text += "Location " & k.ToString & vbCrLf
Dim Spl
Dim sa() As String
End If
If TypeOf entity Is Autodesk.AutoCAD.DatabaseServices.Circle Then
TextBox1.Text += "CIRCLE FOUND " & vbCrLf
Dim Circ As Autodesk.AutoCAD.DatabaseServices.Circle = entity
Dim k
k = Circ.Center
ed.WriteMessage((ControlChars.Lf + "CENT " & k.ToString))
TextBox1.Text += "Centre " & k.ToString & vbCrLf & vbCrLf
Dim Spl
Dim sa() As String
CircFound = CircFound + 1
CircCen(0, CircFound) = CircFound
CircCen(1, CircFound) = sa(0)
CircCen(2, CircFound) = sa(1)
End If
Next id
Finally
myT.Dispose()
End Try
TextBox1.Text += "Text " & TxtFound & vbCrLf
TextBox1.Text += "Circles " & CircFound & vbCrLf
End Sub
"Anders Pettersson" wrote in message
news:4868384@discussion.autodesk.com...
objects in C#.
grateful...
Thanks I'll try that sample!
Do you now any way of getting the geometrical data for objects...
At this point all want to accomplish is to retrieve the polygon points that all objects in an dwg-file. Maybe it's not an arx I should do for this purpose...
