Replace Block - not working with Forms
yoitsarun
yoitsarun
the below code is working fine without form. It is just running with Form but block is not replacing. no error no crash.
private void BtnApply_Click(object sender, EventArgs e)
            var dwg = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            var ed = dwg.Editor;
            var fileNames = GetFileNames();
            if (fileNames is null)
                ed.WriteMessage("\n*Cancel*");
                return;
            ProcessDwgs(fileNames);
            return;
        private IEnumerable<string> GetFileNames()
            IEnumerable<string> files = null;
            using (var dialog = new OpenFileDialog()
                DefaultExt = ".dwg",
                Multiselect = true,
                Filter = "dwg files|*.dwg"
                if (dialog.ShowDialog() == System.Windows.Forms.DialogResult.OK)
                    files = dialog.FileNames;
            return files;
        private void ProcessDwgs(IEnumerable<string> dwgFiles)
            var dwgCol = CadApp.DocumentManager;
            foreach (var dwgFile in dwgFiles)
                var dwg = dwgCol.Open(dwgFile, false, null);
                using (var lck = dwg.LockDocument())
                    ImportBlocks();
                string prefix = "Acad-";
                string newFileName = Path.Combine(Path.GetDirectoryName(dwg.Name), prefix + Path.GetFileName(dwg.Name));
                dwg.Database.SaveAs(newFileName, true, DwgVersion.Current, default);
                dwg.CloseAndDiscard();
        public static void ImportBlocks()
            DocumentCollection dm = Application.DocumentManager;
            string filename = @"C:\new block\new block.dwg";
            Database destDb = dm.MdiActiveDocument.Database;
            try
                var ids = new ObjectIdCollection();
                using (var sourceDb = new Database(false, true))
                    sourceDb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, false, null);
                    using (var tr = sourceDb.TransactionManager.StartTransaction())
                        var bt = (BlockTable)tr.GetObject(sourceDb.BlockTableId, OpenMode.ForRead);
                        foreach (ObjectId id in bt)
                            var btr = (BlockTableRecord)tr.GetObject(id, OpenMode.ForRead);
                            if (!btr.IsAnonymous && !btr.IsLayout)
                                ids.Add(id);
                        tr.Commit();
                    var mapping = new IdMapping();
                    destDb.WblockCloneObjects(ids, destDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, false);
                GC.Collect(); // <- forces a garbage collection
                AcAp.ShowAlertDialog("Blocks importation succeeded");
            catch (System.Exception ex)
                AcAp.ShowAlertDialog(ex.Message);
_gile
Why not also using side databases for batch processing the files?
Here's a way using a generic BatchProcess method.
                return;
            BatchProcess(fileNames, ImportBlocks);
        private string[] GetFileNames()
            using (var dialog = new System.Windows.Forms.OpenFileDialog()
                Multiselect = true,
                    return dialog.FileNames;
            return null;
        public static void BatchProcess(IEnumerable<string> fileNames, Action<Database> action)
            foreach (string fileName in fileNames)
                try
                    using (var db = new Database(false, true))
                        db.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, false, null);
                        action(db);
                        db.SaveAs(fileName, DwgVersion.Current);
                    var ed = Application.DocumentManager.MdiActiveDocument.Editor;
                    ed.WriteMessage($"\nError with '{fileName}': {ex.Message}");
        public static void ImportBlocks(Database destDb)
            try
                                ids.Add(id);
                        tr.Commit();
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
yoitsarun
Thanks _gile . You are awesome.
