Remove colinear vertices polyline
MGO-Norsyn
Message 1 of 13
MGO-Norsyn
Hi everybody.
I was searching for a method to remove colinear vertices from polyline today and couldn't find any thing readily available, so I had to write my own and I want to share this method with anybody needing it in the future.
public static void RemoveColinearVerticesPolyline(Polyline pline)
	List<int> verticesToRemove = new List<int>();
	for (int i = 0; i < pline.NumberOfVertices - 1; i++)
		SegmentType st1 = pline.GetSegmentType(i);
		SegmentType st2 = pline.GetSegmentType(i + 1);
		if (st1 == SegmentType.Line && st1 == st2)
			LineSegment2d ls2d1 = pline.GetLineSegment2dAt(i);
			LineSegment2d ls2d2 = pline.GetLineSegment2dAt(i + 1);
			if (ls2d1.IsColinearTo(ls2d2)) verticesToRemove.Add(i + 1);
	verticesToRemove.Reverse();
	pline.UpgradeOpen();
	for (int j = 0; j < verticesToRemove.Count; j++)
		pline.RemoveVertexAt(verticesToRemove[j]);
Replies (12)
Message 2 of 13
_gile
Here's an example which works with linera and coincident segments.
                if (pline.GetSegmentType(i) == SegmentType.Coincident)
                    pline.RemoveVertexAt(i + 1);
                    i--;
                else if (pline.GetSegmentType(i) == SegmentType.Line)
                    var seg1 = pline.GetLineSegment2dAt(i);
                    switch (pline.GetSegmentType(i + 1))
                        case SegmentType.Line:
                            if (pline.GetLineSegment2dAt(i + 1).IsColinearTo(seg1))
                                i--;
                            break;
                        case SegmentType.Coincident:
                            i--;
                            break;
                        default:
                            break;
Gilles Chanteau
GileCAD
GitHub
Message 3 of 13
_gile
This one also deals with concentric arc segments.
                    pline.RemoveVertexAt(i);
                    i--;
                    var segment = pline.GetLineSegment2dAt(i);
                            if (pline.GetLineSegment2dAt(i + 1).IsColinearTo(segment))
                                i--;
                            break;
                            i--;
                            break;
                        default:
                            break;
                else if (pline.GetSegmentType(i) == SegmentType.Arc)
                    var segment = pline.GetArcSegment2dAt(i);
                        case SegmentType.Arc:
                            var nextSegment = pline.GetArcSegment2dAt(i + 1);
                            if (segment.Center.IsEqualTo(nextSegment.Center) &&
                                segment.IsClockWise == nextSegment.IsClockWise)
                                double bulge = Math.Tan(
                                    Math.Atan(pline.GetBulgeAt(i)) +
                                    Math.Atan(pline.GetBulgeAt(i + 1)));
                                pline.SetBulgeAt(i, bulge);
                                i--;
                            break;
                            i--;
                            break;
                        default:
                            break;
Gilles Chanteau
GileCAD
GitHub
Message 4 of 13
MGO-Norsyn
Hi, thanks for you input, I am sure it will be useful for someone in the future. 😉
I have one question though, I have not tested your methods, but does it really work with polyline's vertices being deleted when iterating over them? I tried that in my method first, but it messed up the vertice's numbers so it was not correct.
I solved it by gathering vertice numbers, then reversing the list with numbers, then removing the vertices starting with the highest number vertice first, så it wouldn't mess up the iteration.
But I see you do the removing the vertices up front and it really works?
Message 5 of 13
_gile
Test it and you'll see it really works...
Gilles Chanteau
GileCAD
GitHub
Message 6 of 13
_gile
Gilles Chanteau
GileCAD
GitHub
Message 7 of 13
MGO-Norsyn
Great!
Message 8 of 13
MGO-Norsyn
Here is my take on removing collinear vertices on a Polyline3d:
PromptEntityOptions peo = new PromptEntityOptions("\nSelect pline 3d: ");
                    peo.AddAllowedClass(typeof(Polyline3d), true);
PromptEntityResult per = editor.GetEntity(peo);
Polyline3d pline = per.ObjectId.Go<Polyline3d>(tx);
PolylineVertex3d[] vertices = pline.GetVertices(tx);
for (int i = 0; i < vertices.Length - 2; i++)
	PolylineVertex3d vertex1 = vertices[i];
	PolylineVertex3d vertex2 = vertices[i + 1];
	PolylineVertex3d vertex3 = vertices[i + 2];
	Vector3d vec1 = vertex1.Position.GetVectorTo(vertex2.Position);
	Vector3d vec2 = vertex2.Position.GetVectorTo(vertex3.Position);
	if (vec1.IsCodirectionalTo(vec2, Tolerance.Global)) verticesToRemove.Add(i + 1);
Point3dCollection p3ds = new Point3dCollection();
for (int i = 0; i < vertices.Length; i++)
	if (verticesToRemove.Contains(i)) continue;
	PolylineVertex3d v = vertices[i];
	p3ds.Add(v.Position);
Polyline3d nyPline = new Polyline3d(Poly3dType.SimplePoly, p3ds, false);
nyPline.AddEntityToDbModelSpace(localDb);
nyPline.Layer = pline.Layer;
pline.CheckOrOpenForWrite();
pline.Erase(true);
Message 9 of 13
bcddss
Hi. You can attach the dll file because not everyone has a visual studio to build the dll file. Thank you
Ahags
Message 10 of 13
kerry_w_brown
With due respect :
This is a peer to peer programming support group, NOT a shopping center.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 11 of 13
bcddss
I understand that this peer-to-peer programming support group focuses on providing guidance and assistance rather than directly sharing files. Thank you for your assistance. My bad, sorry for inconvenience.
Ahags
Message 12 of 13
kibitotato
HOW CAN I USE THIS. I M USED TO USE LISP BUT NOT THIS.
Message 13 of 13
Ed__Jobe
You have to learn C# and the .NET api or you can translate this to lisp. Take a look at the (vlax-curve-????) functions.
BTW, typing in all caps is like yelling.
Ed
How to post your code.
