Remove a vertex
Remove a vertex
Remove a vertex
So as my topic says, how do I remove a vertex from a polyline3d?
Thank for replying,
Bert
[code]
static void DelVertex(void)
ads_name ssName;
ads_point ptres;
int nRet = acedEntSel(_T("\nSelect 3D-polyline: "), ssName, ptres);
if(nRet!=RTNORM) {
acutPrintf(_T("\nLine not selected"));
return;
AcDbObjectId lineId;
AcDbObjectIterator *pVtxIt = NULL;
AcDbObjectIdArray aVtxIds;
int iVtx = 1;
if (acdbGetObjectId(lineId, ssName) == Acad::eOk) {
AcDbObjectPointer pPoly(lineId, AcDb::kForWrite);
if (pPoly.openStatus() != Acad::eOk) return;
pVtxIt = pPoly->vertexIterator();
AcDbObjectId firstId = pVtxIt->objectId();
if(pVtxIt->objectId().isErased()) {
pVtxIt->step();
for (pVtxIt->setPosition(firstId); !pVtxIt->done(); pVtxIt->step()){
if(pVtxIt->objectId().isErased()) continue;
aVtxIds.append(pVtxIt->objectId());
delete pVtxIt;
} else return;
ACHAR prompt[128]=_T("");
sprintf(prompt,_T("\nSelect number of vertex (1 - %d): "),aVtxIds.length());
Acad:ErrorStatus es;
while (acedGetInt(prompt,&iVtx) == RTNORM && (iVtx < 1 || iVtx > aVtxIds.length())) {
acutPrintf(_T("\nError vertex number!"));
if (iVtx >= 1 && iVtx <= aVtxIds.length()) {
AcDbObjectPointer pVt(aVtxIds[iVtx-1], AcDb::kForWrite);
if (pVt.openStatus() == Acad::eOk) {
es = pVt->erase(true);
if (es != Acad::eOk) {
acutPrintf(_T("\nError deleting vertex: %s"), acadErrorStatusText(es));
if (pPoly.openStatus() == Acad::eOk) {
pPoly->recordGraphicsModified(true);
[/code]
Thanks for your reply. It's very nice. But I forgot to say that I'm not used to C# and C++ code. I tried to understand but it seems that I'm not there for now. Look at my code. It works but it do nothing.
PS.: Forget about the transaction, it's initialized and finished outside the function.
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Module MyFunctions
Function CorrectCoordinates(ByVal Poly3d As Polyline3d) As Point3dCollection
Dim P3dCol As New Point3dCollection
Try
For Each objID As ObjectId In Poly3d
Dim vtx As PolylineVertex3d = BertTrans.GetObject(objID, OpenMode.ForRead)
If P3dCol.Count > 0 Then
If vtx.Position.IsEqualTo(P3dCol(P3dCol.Count - 1), New Tolerance(0, 0.001)) Then
vtx.UpgradeOpen()
'I try to erase the vertex from here!
vtx.Erase()
vtx.Dispose()
Else
P3dCol.Add(vtx.Position)
End If
Else
End If
Next
Return P3dCol
Catch ex As Exception
MsgBox(ex.Message)
Return Nothing
End Try
End Function
End Module
Thank,
Bert
