Region Explode
Region Explode
thannaingoo.api
Region Explode
thannaingoo.api
Dear All,
I got an error when I explode the region.
Please help me correct below code.
Naing Oo
 public static void ExplodeRegion(Database db, Editor edt)
            using (Transaction acTrans = db.TransactionManager.StartTransaction())
                BlockTable acBlkTbl;
                acBlkTbl = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                BlockTableRecord acBlkTblRec;
                acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                SelectionSet acSSet = edt.SelectAll().Value;
                if (acSSet == null)
                    return;
                ObjectId[] oids = acSSet.GetObjectIds();
                foreach (ObjectId id in oids)
                    Region reg = (DBObject)acTrans.GetObject(id, OpenMode.ForWrite) as Region;
                    if (reg != null)
                        DBObjectCollection acDBObjColl = new DBObjectCollection();
                        reg.Explode(acDBObjColl);
                        acBlkTblRec.UpgradeOpen();
                        foreach (DBObject dbObj in acDBObjColl)
                            Entity acEnt = dbObj as Entity;
                            acBlkTblRec.AppendEntity(acEnt);
                            acTrans.AddNewlyCreatedDBObject(dbObj, true);
                acTrans.Commit();
_gile
You should provide more details about the error you get and perhaps a dwg example.
I do not see anything wrong in your code,except if some regions are on locked layers.
It just could be more efficient by checking the ObjectId type before opening it, see the code below.
        private static void ExplodeRegion(Database db, Editor ed)
            try
                var regionClass = RXObject.GetClass(typeof(Region));
                using (var tr = db.TransactionManager.StartTransaction())
                    var btr = (BlockTableRecord)tr.GetObject(
                        SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
                    foreach (ObjectId id in btr)
                        if (id.ObjectClass == regionClass)
                            var region = (Region)tr.GetObject(id, OpenMode.ForWrite, false, true);
                            var ents = new DBObjectCollection();
                            region.Explode(ents);
                            foreach (Entity ent in ents)
                                btr.AppendEntity(ent);
                                tr.AddNewlyCreatedDBObject(ent, true);
                            region.Erase();
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage($"\n{ex.Message}\n{ex.StackTrace}");
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
thannaingoo.api
Thanks for your reply and code reference.
I got still an error. Kindly check below link which is my dwg and code.
Naing Oo
https://drive.google.com/open?id=1Wp04frJHtg9MbfanESFk6c4ARJOxOzh9
_gile
Your drawing contains a region which Area and Perimeter is equal to 0. This entity generates an exception with the Explode() method.
Try like this:
            try
                            if (region.Area > 0.0)
                            region.Erase();
                    tr.Commit();
Gilles Chanteau
GileCAD
GitHub
thannaingoo.api
Dear @_gile,
Thanks for your solution.
It is working for me.
I didn't know that we have Area and Perimeter is equal to 0 regions.
Naing Oo
