Reg: XREF send command
Can I know How to use XREF using Send command ,I m using only Interop here
doc.SendCommand("XATTACH" + " " + Fname + " " + " " + "0,0,0" +" "); but its not working can anyone help me out.
Norman_Yuan
"It does not work" does not provide much information about what exactly your issue is. Any error message, how do you call AcadDocument.SendCommand() (the code executed before and after the call, which does matter if you HAVE TO use SendCommand())?
But, since you use COM Interop, why do you have to use SendCommand() to attach XRef instead of using AcadModelSpace/PaperSpace.AttachExternalReference()?
Norman Yuan
Drive CAD With Code
Thank U SO MUCH I ACTUALLY DIDNT KNOW AcadModelSpace/PaperSpace.AttachExternalReference this method,Its helpful now
Detach ,we have to use Block table record then only we have to Detach or else any Direct method is there?
Norman_Yuan
An Xref is an AcadBlock.
So, you loop through ThisDrawing.Blocks collection, search for AcadBlock with IsXref = True. Once you find the targetting AcadBlock (Xref), you can call
AcadBlock.Bind/Detach/Reload/Unload()...
Norman Yuan
Drive CAD With Code
