RealDWG exception on RuntimeSystem.Initialize(new ApplicationHost(), 1033)
I am new to RealDWG and am attempting to get a simple application working that reads Title blocks from DWG drawings. On the first line of my RealDWG 2010 application I get the following exception:
The specified module could not be found. (Exception from HRESULT: 0x8007007E)
 This occures when I call the following method:
I have installed RealDWG 2010 x86 on my 64bit Windows 7 PC, am building the assembly with the StrongNameKey file and the correct license information. I have also added the following path to my PATH environment variable:
     C:\Program Files (x86)\RealDWG 2010
I have also attempted this with the x64 RealDWG installation, with the same result. I assume that there is something simple that I am missing such as a required dependency, but cannot figure out what it might be.
Could you please advise what I need to do to resolve this issue?
Thanks and Regards,
Sean Hunter
Onset Design
This was resolved by adding C:\Program Files (x86)\RealDWG 2010 to the start of the path variable.
