RealDWG 2018 Ad22asm.msm
cgcamilo
cgcamilo
Hello, I am trying to integrate the new RealDWG 2018 library into my application. Previously I had RealDWG2015.
My question is, in the read me file "C:\Program Files\Autodesk\RealDWG 2018\Docs\readdbx.chm" there is a section "Redistribution Requirements", in this section I can see all !Required Components" under "Merge Module Listing for Redistributable Components". There is this Ad22asm.msm merge module listed there but I cannot find it anywhere and I believe it is required. Thank you.
Camilo Cifuentes
I am seeing the same issue with both the 32 and 64 bit versions of the RealDWG 2018 SDK installs. In addition to the missing file (Ad22asm.msm), I am also seeing the following files missing:
Asm222_acmessages.msm
*Asm222_acad.msm
*Asm222_acmodlr.msm
* The documentation probably has the wrong name.
I'm also curious what merge modules are required. In my case, I am only wanting to read drawing properties and read/write xref path information.
