Read SoftPointerId From ResultBuffer
youssefGC
youssefGC
Hi everyone,
I have stored information of type "ObjectId" (as SoftPointerId) in an entity, but in read data I found the problem "Impossible to cast an object of type ObjectId to type String", it doesn't work in my case.
Thank you.
norman.yuan
You can simply
var id=(ObjectId)result[0].Value;
Note, the ObjectId could be ObjectId.Null, if the underline entity no long exists (i.e. was erased), or its IsErased property could be true, if the underline entity was just erased prior to the ResultBuffer is retrieved.
Norman Yuan
Drive CAD With Code
Gepaha
ObjectId idOfRebarEch = (ObjectId)result[0].Value;
if (idOfRebarEch.IsValid)
