Put in a value after inserting block with attribute
kebby70
kebby70
I'd like to put in a value after inserting block with attribute.
Attribute is Number.
Insert 5 block, each number is automatically increasing.
Below is my code.
Inserted block is success, I'dont know how to put in a value to attribute.
[CommandMethod("uuu", CommandFlags.NoHistory)]
public void BlockSimple()
Document acDoc = Application.DocumentManager.MdiActiveDocument;
Database acDocDb = acDoc.Database;
Editor acDocEd = acDoc.Editor;
Database workingDB = HostApplicationServices.WorkingDatabase;
string fpFile = @"C:\LIBRARY\FP_TEST.dwg";
string fpBlock = @"FP_TEST";
using (DocumentLock acLckDoc = acDoc.LockDocument())
using (Transaction acTrans = acDocDb.TransactionManager.StartTransaction())
Database db = null;
db = new Database(false, false);
db.ReadDwgFile(fpFile, System.IO.FileShare.Read, true, null);
ObjectId NewBlkId = new ObjectId();
NewBlkId = acDocDb.Insert(fpBlock, db, false);
BlockTable bt = (BlockTable)acTrans.GetObject(acDocDb.BlockTableId, OpenMode.ForWrite, true);
BlockTableRecord btr = (BlockTableRecord)acTrans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
BlockReference blkRef = new BlockReference(new Autodesk.AutoCAD.Geometry.Point3d(0, 0, 0), NewBlkId);
btr.AppendEntity(blkRef);
acTrans.AddNewlyCreatedDBObject(blkRef, true);
AcadApplication acadApp = (AcadApplication)acApplication.Application.AcadApplication;
acadApp.ActiveDocument.SendCommand("_.ATTSYNC N " + fpBlock + "\n");
acDocEd.Regen();
db.Dispose();
acTrans.Commit();
norman.yuan
Since your code create the block reference, you do not call "ATTSYNC" to add attribute. Instead, your code should create AttributeReference based on the BlockTableRecord. Following quick code does it:
[CommandMethod("UUU", ...)]
public static CreateBlock()
  using (acDoc.LockDocument())
    InsertBlock(acDocDb, "C:\\LIBRARY\\BlockFile.dwg");
private static InsertBlock(Database docDb, string fileName)
  // create block definition from external block file
  ObjectId blockDefId=InsertBlockDefinition(docDb, fileName);
  // insert block reference
  using (var tran=db.TransactionManager.StartTransaction())
     BlockTableRecord space =
    BlockTableRecord blockDef=
           (BlockTableRecord)tran.GetObject(blockDefId, OpenMode.ForRead)
    // create the block reference 5 times
    for int i=1; i<=5; i++)
       var insPt=newPoint3d(0.0, i * 10.0, 0.0);
       InsertBlockReference(blockDef, insPt, space, tran, i);
    tran.Commit();
private ObjectId InsertBlockDefinition(Database docDb, string fileName)
  var id=ObjectId.Null;
  using (var db=new Datyabase(false, true))
     db.ReadDwgFile(fileName,.......);
     id=docDb.Insert(
        System.IO.Path.GetFielNameWithoutExtension(fileName), db, false);
  return id;
private static void InsertBlockReference(
             BlockTableRecord blockDef, Point3d insPt, BlockTableRecord space, Transaction tran, int num)
    var blockRef=new BlockTableRecord(insPt, blockDef.ObjectId);
    blockRef.SetDatabaseDefault();
    space.Append(blockRef);
    tran.AddNewlyCreatedDBObject(blockRef, true);
    // following code add attributereference to the block reference, based
    // on block definition
   foreach (ObjectId id in blockDef)
      var att=trans.GetObject(id, OpenMode.ForRead)  as AttributeDefinition;
      if (att!=null && !att.Constant)
         var attRef=new AttributeReference();
         attRef.SetAttributeFromBlock(att, blockReference.BlockTransform);
         if (att.Tag.ToUpper()=="NUMBER") att.TextString=num.ToString();
         blockRef.AttributeCollection.Append(attRef);
         tran.AddNewlyCreatedDBObject(attRef, true);
The code is not tested, but you get the idea.
HTH.
Norman Yuan
Drive CAD With Code
kebby70
Thanks a lot for your code.
I tested and found that the first block is missing attribute value.
[CommandMethod("UUU", CommandFlags.NoHistory)]
public void CreateBlock()
InsertBlock(acDocDb, @"C:\LIBRARY\FP_J02-019.dwg");
private void InsertBlock(Database acDocDb, string fileName)
ObjectId blockDefId = InsertBlockDefinition(acDocDb, fileName);
using (var acTrans = acDocDb.TransactionManager.StartTransaction())
BlockTableRecord space = (BlockTableRecord)acTrans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
BlockTableRecord blockDef = (BlockTableRecord)acTrans.GetObject(blockDefId, OpenMode.ForWrite);
for (int i = 1; i <= 5; i++)
var insPt = new Point3d(-20.0, i * 20.0, 0.0);
InsertBlockReference(blockDef, insPt, space, acTrans, i);
acTrans.Commit();
var id = ObjectId.Null;
using (var db = new Database(false, true))
db.ReadDwgFile(fileName, System.IO.FileShare.Read, true, null);
id = docDb.Insert(System.IO.Path.GetFileNameWithoutExtension(fileName), db, false);
return id;
private static void InsertBlockReference(BlockTableRecord blockDef, Point3d insPt, BlockTableRecord space, Transaction acTrans, int num)
var blockRef = new BlockReference(insPt, blockDef.ObjectId);
blockRef.SetDatabaseDefaults();
space.AppendEntity(blockRef);
acTrans.AddNewlyCreatedDBObject(blockRef, true);
var att = acTrans.GetObject(id, OpenMode.ForWrite) as AttributeDefinition;
if (att != null && !att.Constant)
var attRef = new AttributeReference();
attRef.SetAttributeFromBlock(att, blockRef.BlockTransform);
if (att.Tag.ToUpper() == "LOC") att.TextString = num.ToString();
if (att.Tag.ToUpper() == "INST") att.TextString = "ITB";
blockRef.AttributeCollection.AppendAttribute(attRef);
acTrans.AddNewlyCreatedDBObject(attRef, true);
norman.yuan
Well, if you step through the code in debug with break point in the method InsertBlockReference(), it would be quite easy to find out why the fifth block's attributes are not added, or added but its TextString not set.
Norman Yuan
Drive CAD With Code
kebby70
Thanks....I've resolved..
Changed to attRef
if (attRef.Tag.ToUpper() == "LOC") attRef.TextString = num.ToString();
if (attRef.Tag.ToUpper() == "INST") attRef.TextString = "ITB";
