Print attributes of a block with LISP
I am new to the LISP world. I am trying to extract or print the attributes of several blocks that are in the same layer.
the layer in which these blocks are located is called: PROJECTED TRAFO
The names of the attributes are
KVA_TRAFO = T10: 15 KVA
No_TRAFO = 8UN-11UP
I want to extract this data to eventually export it to an excel table. but at the moment I just want to print them.
Could you give me some idea to achieve this.
Thanks in advanced!
norman.yuan
You posted in wrong forum. This is for .NET API. For LISP, it is here.
Norman Yuan
Drive CAD With Code
