public has an error message under public static void for the following code
irahmanJS6UB
irahmanJS6UB
Hello, for the following code I get a red line under public and I am not sure as to why, can someone help me?
[CommandMethod("OpenDrawing", CommandFlags.Session)]
public static void OpenDrawing()
string strFileName = "C:\\campus.dwg";
DocumentCollection acDocMgr = Application.DocumentManager;
if (File.Exists(strFileName))
acDocMgr.Open(strFileName, false);
else
acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " + strFileName +
" does not exist.");
Thank you!
AVCPlugins
Look in the error message box. You probably didn't declare a namespace and a public class. It feels like you should read the VS tutorial first and compile "Hello world".
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
kpblc2000
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using System.IO;
namespace Aspecific.AcadCommands
    public static class TestCommand
            else
Perhaps this?
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Алексей Кулик aka kpblc | Aleksei Kulik aka kpblc Facebook | LinkedIn
autolisp.ru
Техническая поддержка программистов Autodesk в СНГ
Библиотека пользовательских lisp-функций | Custom Lisp-function library
_gile
I suspect you didn't start your project from a "class library" one.
You can start from this topic to see how to create an AutoCAD .NET project.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
