proxy object version
JamesMaeding
Advisor Advisor
JamesMaeding
I have a version 2007 drawing that may have civil3d surfaces from 2017, 2015.
I found the props for ProxyEntity here:
https://www.theswamp.org/index.php?topic=44950.msg501586#msg501586
but am not clear on how to determine the version of the object enabler that created them.
I want to be able to say "this 2007 drawing has or does not have surfaces from 2015", same for 2017.
Just knowing they are a proxy from aeccsurface class is not enough.
Anyone done that?
This is a generic question, not really specific to c3d surfaces, just using that as an example.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
_gile
As far as I know, neither ProxyObject nor ProxyEntity types expose much properties.
From the docs:
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
fieldguy
Is there xdata on the objects?  If there is, you can find the "Registered Application Name" but I am not sure there is an entity type, like "Surface".
JamesMaeding
Fieldguy,
Understand that a registered application name has nothing to do with a proxy objects class name or version.
If a regapp did have some kind of version info, it would be completely coincidence and unreliable, especially considering most programmers would not want to change those names from version to version. I myself use them and always make them generic named.
Not to show how incredibly knowledgeable I am, ha ha, I say this because I fight the regapp war with autodesk, and so many people get confused on regapps.
Gile,
You are going to die of over-kudos. Your nice responses are making autodesk look bad.
Alexander.Rivilis
It is look like only reading dxf-groups of Proxy can help you: http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-F59F0EC3-D34D-4C1A-91AC-7FDA569EF016
95
DXF: Object drawing format when it becomes a proxy (a 32-bit unsigned integer):
Low word is AcDbDwgVersion
High word is MaintenanceReleaseVersion
Also group 310 contain information about original object/entity. Usually (but not always) some first bytes contains version information.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
JamesMaeding
great suggestion, but I do not see the 95 group for a c3d surface from 2017 opened in 2015:
(-1 . <Entity name: 7ff600c20b00>)
(0 . "ACAD_PROXY_ENTITY")
(5 . "C60")
(102 . "{ACAD_XDICTIONARY")
(360 . <Entity name: 7ff600c21b60>)
(102 . "}")
(330 . <Entity name: 7ff600c139f0>)
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "0")
Immediately I see my surface is an  "ACAD_PROXY_ENTITY", not  "ACAD_PROXY_OBJECT", so not too surprised.
I will have to play around a bit to see if entgetting the 360 or 330 items yield additional info.
Also listing gives this:
ACAD_PROXY_ENTITY Layer: "0"
Space: Model space
Handle = c60
DXF name: AECC_TIN_SURFACE
Class name: AeccDbSurfaceTin
Application name: AeccLand110
Product Desc: AutoCAD Civil 3D
Company: Autodesk,Inc.
WEB Address: www.autodesk.com
I wonder if the AeccLand110 is keyed to the version
Alexander.Rivilis
(5 . "C60")
(102 . "}")
(67 . 0)
(410 . "Model")
(8 . "0")
Please attach file with one c3d surface. It is interesting to me investigate this.
Expert Elite Member
