Programmatically determine BlockReference.BlockName of AttributeCollection
Here is a quick background for what I am trying to do:
Essentially, I need to loop through and update a set of attributes which match the following set of requisites:
    1. The AttributeCollection must contain a provided Tag name
    2. The AttributeCollection must be a property on a BlockReference which matches a specific Block name
    3. The AttributeCollection must be a property on a BlockReference which is a DynamicBlock
I believe I have issues 1 and 3 solved, but 2 is throwing me off. While looping through the BlockReferences, the BlockReference which contains the AttributeCollection does not have a Name which matches what is displayed in the Enhanced Attribute Editor. For example, the .NET code will report that the BlockReference.Name is something similar to *U16, and BlockReference.BlockName is *Model_Space, when the Enhanced Attribute Editor states that "Block: My_Expected_Block_Name". What I really need to do is tie the BlockReference back to "My_Expected_Block_Name".
Am I looking in the wrong spot for matching an AttributeCollection to a specific Block Name, or using the wrong properties? Any direction I can get would be helpful. I don't know my way around AutoCAD very well, as I am just stepping in to assist another user with some .NET programming.
If more information is necessary, let me know - I will post the code I am using to loop below.
Code:
// Assume that "db" is a Transaction which has been opened by a StartTransaction() call
// Assume that "AutoCADHelper.CurrentAcadDb" is DocumentManager.MdiActiveDocument.Database
var blockTable = (BlockTable)db.GetObject(AutoCADHelper.CurrentAcadDb.BlockTableId, OpenMode.ForRead);
foreach (ObjectId blockTableId in blockTable) {
    var blockTableRecord = db.GetObject(blockTableId, OpenMode.ForRead) as BlockTableRecord;
    if (blockTableRecord != null) {
        foreach (ObjectId blockTableRecordId in blockTableRecord) {
            var blockReference = db.GetObject(blockTableRecordId, OpenMode.ForWrite) as BlockReference;
            if (blockReference != null && blockReference.IsDynamicBlock) {
                Debug.WriteLine(" blockReference.Name: " + blockReference.Name); // I would assume one of these would be the expected name
                Debug.WriteLine(" blockReference.BlockName: " + blockReference.BlockName); // but I am clearly wrong. 🙂
norman.yuan
It looks like you need to understanding a bit more about dynamic block.
I believe what you are after is BlockReference.Name, not BlockReference.BlockName. BlockName property refers to blockreference's owner (a blocktablerecord, either ModelSpace, or one of the PaperSpace corresponding to a layout).
For regular blockreference, its Name property is the same name as the name of a BlockTableRecord (block definition), from which it is referenced to. However, if the block definition is a dynamic block, the BlockReference's name may not be the same as its block definition, depending on how the dynamic properties are set. It name is very likely be a anonymous block name, something like *Uxxx". You need to use Blockreference.DynamicBlockTableRecord to find its dynamic blcok definition and then its name.
To find effective name (as iin VBA) of a blockreference, you do:
//tran is an open Transaction
//modelSpaceBlockTableRecord is the BlockTableRecord for ModelSpace
foreach (ObjectId id in modelSpaceBlockTableRecord)
    string blockName;
    BlockReference bref=tran.GetObject(id, OpenMode.ForRead) as BlockReference;
    if (bref!=null)
        if (bref.IsDynamicBlock)
             BlockTableRecord br=(BlockTableRecord)tran.GetObject(bref.DynamicBlockTableRecord,OpenMode.ForRead);
             blockName=br.Name;
        else
            blockName=bref.Name;
        Debug.WriteLine("Found block reference: " + blockName);
Norman Yuan
Drive CAD With Code
I certainly do need more understanding. 🙂 So thank you! That's very helpful to me.
