Programmatically access layer info
i'm stuck and in case my last question wasn't clear i've attached an image.  i can access the General layer properties thru the api (circled in green on image).  how can i programmatically access the Attributes (circled in red).  is this possible? thanks.
Alfred.NESWADBA
If you have the BlockReference already at your hand, you can access the .AttributeCollection which gives you a list of ObjectIDs, every one pointing to each single AttributeReference attached to the BlockReference.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
