Problem with PaletteSet location in Autocad
Message 1 of 25
I'm having problem with chosing PalleteSetSet location in Autocad. No matter what I do, it is always docked on left side of Autocad window. My code is something like this:
PaletteSet ps;
ps = new PaletteSet("blabla", new Guid(System.Guid.NewGuid().ToString("B")));
ps.Style = PaletteSetStyles.NameEditable | PaletteSetStyles.ShowPropertiesMenu |
PaletteSetStyles.ShowAutoHideButton | PaletteSetStyles.ShowCloseButton;
ps.MinimumSize = new System.Drawing.Size(Width,Height);
ps.Size = new System.Drawing.Size(.Width,Height);
ps.DockEnabled = Autodesk.AutoCAD.Windows.DockSides.None;
ps.Add("blabla", new Palette());
ps.Visible = true;
Am I missing something? Edited by: JernejC on Sep 25, 2009 8:42 AM
Replies (24)
Message 21 of 25
Alfred.NESWADBA
have you found that blog:
>>>Database.ThumbnailBitmap returns Nothing when called for a side database<<<?
I think that will be the answer.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 22 of 25
Hi alfred,
I have no idea what is wrong in this project 🙂
I changed like this:
public System.Drawing.Bitmap get_image_of_file(string filename)
//create a new database instance and load the dwg file into it.
Database dbb = new Database(false, true);
//dbb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, false, "");
dbb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndReadShare, true, "");
MessageBox.Show(filename);
//grab the thumbnail bitmap and get rid of the white background
System.Drawing.Bitmap preview = dbb.ThumbnailBitmap;
// preview.MakeTransparent(System.Drawing.Color.White);
return preview;
and it did not work. Error is the same.
Messagebox show me path to DWG file - is correct.
But I thank you for your patience and help 🙂
My control "Palette" look like:
in AutoCAD (during run & debug), my Palette look like:
no label.control, no background.color - This is weird, do not you think?
Maybe I do something wrong in other place?
regards
Message 23 of 25
Alfred.NESWADBA
do you have an older version of AutoCAD? I did test the attached project in debug-mode (with AutoCAD 2010) and it shows the preview icon. Update the references and verify it on your system.
-.alfred -
Alfred NESWADBA
Message 24 of 25
Hi Alfred,
I don't have AutoCAD2010, but I did test in AutoCAD2012.
It's work good, but... I noticed that some of the blocks are correct, others do not.
In attached are two blocks: 2010 not read, 2011 read.
Maybe here is the problem, not in program?
regards
Message 25 of 25
Alfred.NESWADBA
the 2010.DWG is a definition of a dynamic block, so when you open this drawing you get the question like that.
When opening your block with your preview-tool I get then this exception:
makes me thinking that opening a dynamic-blockdefinition is not supported yet by the API (at least with AutoCAD-2010).
 In this case I would understand some difficulties to querying the thumbnail from the db-object.
But the 2011.DWG does work with your preview (at my workstation/with AutoCAD 2010).
- alfred -
Alfred NESWADBA
