problem with loading a dll file from a network
Message 1 of 8
Dear friends:-
I deveolped a dll file and I put it on the network in my company, the problem is when the user netload this dll file from his PC a error message shows securitry policy ---etc, I searched the internet and I found this batch file:
c:\windows\microsoft.net\framework\v2.0.50727\Caspol.exe -m -ag 1.2 -url \\ZFPCFS\ZFP-IS\ZFP-IDS\CAD\L\LAB6.dll FullTrust but its still not working I don't know what I shall do, Kindly help me
Replies (7)
Message 2 of 8
michael_robertson
If you trust everything running on local servers you can use:
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\CasPol.exe -m -cg LocalIntranet_Zone FullTrust
This way you don't have to create an entry for every application you load on your server.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 3 of 8
michael_robertson
Just to confirm, when you run the Caspol commands, you are running the command on the workstation accessing the server (not the server itself), correct?
Mike Robertson
Message 4 of 8
No Sir I run it from the user Local PC
Message 5 of 8
Dear Michael:-
thank you for reply I tryed your idea but its still not working i don't know why!!
Message 6 of 8
michael_robertson
Could you post the entire error message?
Mike Robertson
Message 7 of 8
Here is the error message, but I just found some thing, when I press on the the continue buttom try fire the command befor exit autocad its working I don't know what happend ??
Message 8 of 8
Sorry michael the application appear put its still not working.
