Problem when insert and move a block references
jamalkhah
Message 1 of 18
jamalkhah
Hi everyone
I want to insert a block reference to my drawing. Sometimes I have a problem with moving. When the block reference is inserted, the base point has moved away from the lines and lines will show in the wrong position.
The piece of code I used is:
            using (DocumentLock dlock = doc.LockDocument())
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    #region bt
                    // Open the Block table for read
                    BlockTable bt;
                    bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                    ObjectId blockId = ObjectId.Null;
                    if (bt.Has(blockName))
                        blockId = bt[blockName];
                    else
                        return;
                    #endregion
                    // Focus on drawing
                    Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView();
                    using (BlockReference br = new BlockReference(Point3d.Origin, blockId))
                        #region Move BlockReference
                        Point3d p3d = Point3d.Origin;
                        Vector3d vector3D = p3d.GetVectorTo(insertPoint.Point3d());
                        br.TransformBy(Matrix3d.Displacement(vector3D));
                        #endregion
This problem only happens sometimes and this code works correctly most of the time.
How can I fix it?
Replies (17)
Message 2 of 18
ActivistInvestor
Why not just set the initial insertion point of the block reference to the point that you are trying to transform it to?
You are also missing something relevant. I do not know what this is:
Message 3 of 18
jamalkhah
1- I have tried this solution before, problem is the same.
2. insertPoint.Point3d() : Point3d() is a function that converts Point2d to Point3d.
Message 4 of 18
jamalkhah
Update:
Recently, I found the reason for this problem in my tests. Before using this method, if I use the "Paste to original coordinates" option in AutoCAD when pasting something, the base point of this block reference will be moved by the distance of the copied item from the point (0, 0, 0). But this does not always happen, only sometimes!
What happens when using "Paste to original coordinates" that affects the result of my method?
Message 5 of 18
_gile
It seems your issue is not due to the code you posted but to the way the block definition (BlockTableRecord) was created. Try to open the block in the block Editor and see the position of entities about the origin.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 18
jamalkhah
In the Block Editor, I have a Basepoint. When the code works properly, the Basepoint is in the right position, but when this problem occurs, the entities will move to another position.
Before, when I did not use basepoints, I used to draw the entities at the origin. When the problem arose, the entities were moved together from the origin.
Message 7 of 18
_gile
Isn't there a coordinate system issue?
Is the current UCS different from WCS when the problem happens and equal to WCS "most of the time"?
A good practice is to always transform coordinates of points got by Editor.GetPoint into WCS coordinates.
var promptPointResult = ed.GetPoint("\nSpecify insertion point: ");
if (promptPointResult.Status != PromptStatus.OK) return;
var insertionPoint = promptPointResult.Value.TransformBy(ed.CurrentUserCoordinateSystem);
Gilles Chanteau
GileCAD
GitHub
Message 8 of 18
jamalkhah
Thanks, Gile
I will try this method but it doesn't seem to be the solution. The problem is that the block reference is manipulated after the execution of my code and the entities are moved!
Message 9 of 18
_gile
Sorry, I do not understand what you mean with: "the block reference is manipulated after the execution of my code and the entities are moved"
Gilles Chanteau
GileCAD
GitHub
Message 10 of 18
_gile
You should post a relevant example with a block insterted with your code at a simple point (e.g. 10, 10, 0) and another inserted directly (without code) which reflect what you expected..
Gilles Chanteau
GileCAD
GitHub
Message 11 of 18
jamalkhah
I explained it in my first post. Entities moved from their original position to another position (It can be seen in the block editor).
This move usually occurs after the use of the "Paste to original coordinate" option and the moving vector is equal to the size of the displacement vector of the copied entities from the origin.
For example, if I copy a polyline to my drawing to its original coordinates, and its original coordinates are (100, 200, 0), and after that, execute my code, the entities inside my block reference, will move by the vector (100, 200, 0).
Did I get my point across?
Message 12 of 18
_gile
So, my first reply (#5) was relevant.
When you create the block definition (BlockTableRecord), you have to displace all "copied entities" using a vector from the specified insertion point to origin.
You can see this topic with an example of custom command which mimics the native BLOCK command to create a block definition from selected entities and an insertion point.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 18
jamalkhah
What I expect:
 What happens after the code is executed:
In both images, the blue point is the block reference basepoint. In the second image, the code has placed the block reference in the correct place, but the entities have moved away from the base point.
Message 14 of 18
jamalkhah
Block editor - Before code execution:
Block editor - Aftercode execution:
Message 15 of 18
_gile
What you see in the block editor is the block definition (BlockTableRecord) and the code you posted just insert a block reference (BlockReference). So the changes in the block definition cannot be due to code you posted.
Gilles Chanteau
GileCAD
GitHub
Message 16 of 18
ActivistInvestor
What you show is the result of redefining the block to have a different base point. That has nothing to do with code that inserts the block.
Unintended changes to the base point of a block could be the result of defining or redefining the block with a current UCS that is not the WCS.
Message 17 of 18
jamalkhah
Could this be due to copying some entities from another source in the drawing?
Message 18 of 18
ActivistInvestor
Entities that are copied from another drawing will have the same coordinates as the original entities had, unless they were transformed after being copied.
