Problem when debugging AutoCAD 2011 with Visual Studio 2013
I'm running Visual Studio 2013 with AutoCAD 2011 on Windows 7 Enterprise, 64 Bit. When starting the VS Debugger AutoCAD opens normally. I netload my dll from the debug folder, I set a break point in VS, but when I run the plugin it does not stop at the break point. I have no errors in the plugin and it runs as expected, but I want to step through it with the debugger. When I switch to VS it is in debug mode, but there is no highlighted line and I can get no response from it. I can't step through or do anything other than stop debugging which then closes AutoCAD. Any suggestions would be appreciated.
I found the solution to my problem in KEAN WALMSLEY Blog. http://through-the-interface.typepad.com/through_the_interface/2010/04/hitting-breakpoints-in-net-cl... I used 'Solution 3' and break points are now working.
