Problem calling acedCmd
HJohn1
Message 1 of 10
HJohn1
I am using TT's CommandLine class in my project. Initially, when I loaded the project in AutoCAD 2014 I had to change "acad.exe" to "accore.dll" and it worked fine and continues working fine in my developing machine.  Now, I am having problems in some computers where the commandline class seems to be not working properly. It seems to me that I had come across some posts that talked about the differences in the function signature for 32 and 64bit platforms, however now I can't find any information about it.  Can someone give me some help on this issue.  It will be really appreciated.
Replies (9)
Message 2 of 10
DiningPhilosopher
There's no need to P/Invoke acedCmd() directly on recent releases of AutoCAD
thanks to the RunCommand wrapper (not sure what release it appeared in initially).
acedCmd() doesn't support the use of managed selection sets, but RunCommand()
does (it handles that internally for you) and allows them to be passed as arguments
where a command is expecting a selection set.
See this post:
http://forums.autodesk.com/t5/NET/Send-Command-Executes-after-exiting-command-method/td-p/3882929
Message 3 of 10
HJohn1
DP thank you very much for your help, very appreciated.  Now, would it be to much to ask if there is, you have or have seen a VB version.  I am using VS2010 Express and can not use C# code.  Trying to Port it myself will make the few hair left to fall out.
Message 4 of 10
_gile
Here's a VB conversion of Tony's RunCommand wrapper.
With VB, extension methods have to be defined a module. If the module isn't part of the same namespace, you have to import it:
Imports EditorInputExtensionMethods
    Module EditorInputExtensionMethods
       <System.Runtime.CompilerServices.Extension> _
       Public Function Command(editor As Editor, ParamArray args As Object()) As PromptStatus
           If editor Is Nothing Then
               Throw New ArgumentNullException("editor")
           End If
           Return runCommand(editor, args)
       End Function
       Dim runCommand As Func(Of Editor, Object(), PromptStatus) = GenerateRunCommand()
       Private Function GenerateRunCommand() As Func(Of Editor, Object(), PromptStatus)
           Dim method As MethodInfo = GetType(Editor).GetMethod( _
               "RunCommand", BindingFlags.Instance Or BindingFlags.NonPublic Or BindingFlags.[Public])
           Dim instance As ParameterExpression = Expression.Parameter(GetType(Editor), "editor")
           Dim args As ParameterExpression = Expression.Parameter(GetType(Object()), "args")
           Return Expression.Lambda(Of Func(Of Editor, Object(), PromptStatus)) _
               (Expression.Call(instance, method, args), instance, args).Compile()
       End Function
   End Module
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 5 of 10
DiningPhilosopher
I see that Giles has help you out (thanks Giles)
Message 6 of 10
HJohn1
Thank you both for your help. I have marked both of your posts as solutions, since it is what I was looking for.  However, I have not been able to run or test this solution.  Since the moment I added the ExtensionMethod to my project, I am getting a error message on VS 2010 that says "No Source Available".  I am going to create a separate post about this issue.  I have never come across something like this, but it seems to be common.
Message 7 of 10
HJohn1
I was able to build the project and run the code, and your solution works very well, so thanks again.
Message 8 of 10
I am having trouble with the EditorinputExtensionMethods.  I'm not sure what I'm doing wrong, but when I call the editor.Command(parameters), absolutely nothing happens.  I have access to the editor, because the editor.WriteMessage command works.  I am calling the editor.Command from a button click on a windows form in a module loaded into AutoCAD with NETLOAD.  Any insight would be greatly appreciated!  Code is inserted below.
Imports System
Imports System.Collections
Imports System.Collections.Generic
Imports System.IO
Imports System.Linq
Imports System.Reflection
Imports System.Linq.Expressions
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports System.Windows.Forms
Imports System.Runtime.InteropServices
Imports System.Data.SqlServerCe
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.ApplicationServices.DocumentExtension
        End If
    End Function
            "RunCommand", BindingFlags.Instance Or BindingFlags.NonPublic Or BindingFlags.Public)
        'Dim instance As ParameterExpression = Expression.Parameter(GetType(Editor), "instance")
    End Function
End Module
Public Class frmMhsApp
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        Dim doc As Document =
                  Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        ed.Command("._line", New Point3d(0, 0, 0), New Point3d(5, 5, 0))
        ed.WriteMessage("Message Test")
    End Sub
Message 9 of 10
I found my issue!  I had to load my form as follows:
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(frmApp)
Hope this helps someone else.
Message 10 of 10
I'm having the same issue as bruceamcd. Without a form it works fine.
But using a form with either Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog or ShowModelessDialog it doesn't.
I'm using Tony's Runcommand wrapper from Autocad 2014 x64.
FIBERWORLD is set to 1 as required.
Any thoughts on what might cause this behavior are welcome. thanks.
