Problem by PromptResult in combi of getDistance
jan_tappenbeck
jan_tappenbeck
Hi
this post is in connection to https://forums.autodesk.com/t5/net/getdistance-in-combination-of-using-a-rubber-band/td-p/11553064.
my code is currently
Dim Radius_1 As Double = 10.0
Dim pDistOpts_1 As PromptDistanceOptions = New PromptDistanceOptions(vbLf &
												String.Format("Radius 1 <{0}>: ", Radius_1.ToString("0.000"))) With {.AllowNone = True,
																													 .BasePoint = Point_1,
																													 .UseBasePoint = True,
																													 .UseDashedLine = True,
																													 .Only2d = True}
Dim pStrRes_1 As PromptResult = AcEditor.GetDistance(pDistOpts_1)
Select Case pStrRes_1.Status
	Case PromptStatus.OK ' der erfasste Abstand
		'Radius_1 = pStrRes_1.
		Dim Value_1 As String = pStrRes_1.StringResult
		If IsNumeric(Value_1) = True Then
			Radius_1 = Math.Abs(CDbl(Value_1))
		Else
			_AcLog.Write("keine gültige nummerische Eingabe für Punkt 1!")
			Exit Sub
		End If
	Case PromptStatus.None ' hier wird die Vorgabe übernommen
	Case Else 'bevor es zu einem Fehler kommt
		Exit Sub
End Select
till line 11 everything is ok.
but then when i want to access to the result pStrRes_1.StringResult will be nothing and in context-menu there is a property value.
but when i code in ide pStrRes_1.value i get the message "value is not a member of PromptResult" !
i did not understand....
regards Jan
_gile
The following code should suit your needs. It also uses the PromptDistanceOptions.DefaultValue property so that the PromptDistanceResult.Status cannot be anything else than OK or Cancel.
If PromptDistanceResult.Status equals OK, the PromptDistanceResult.Value is always a double.
            var distanceOptions = new PromptDistanceOptions("\nRadius 1:")
                AllowNone = true,
                BasePoint = point1,
                UseBasePoint = true,
                UseDashedLine = true,
                Only2d = true,
                DefaultValue = radius1,
                UseDefaultValue = true
            var distanceResult = ed.GetDistance(distanceOptions);
            // the PromptDistanceResult.Status is either OK or Cancel
            switch (distanceResult.Status)
                case PromptStatus.OK:
                    radius1 = distanceResult.Value; // this value is always a double
                    break;
                default:
                    return;
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
