Polyline(Clone) problem
brianchapmandesign
brianchapmandesign
Strange...when using this it's literally exploding my original polyline. Is clone inttended to work this way?
            Polyline newpoly = new Polyline();
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptEntityResult per = ed.GetEntity("Select a polyline");
            if (per.Status == PromptStatus.OK)
            using (Transaction Tx = db.TransactionManager.StartTransaction())
                // Open the Block table for read
                BlockTable acBlkTbl;
                acBlkTbl = Tx.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                // Open the Block table record Model space for write
                BlockTableRecord acBlkTblRec;
                acBlkTblRec = Tx.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                DBObject obj = Tx.GetObject(per.ObjectId, OpenMode.ForRead);
                Polyline lwp = obj as Polyline;
                newpoly = lwp.Clone() as Polyline;
                newpoly.ColorIndex = 1;
                acBlkTblRec.AppendEntity(newpoly);
                Tx.AddNewlyCreatedDBObject(newpoly, true);
                Tx.Commit();
"Very funny, Scotty. Now beam down my clothes.
_gile
I cannot reproduce what you're describing with your code.
Anyway, you create a new Polyline:
 but never add it to the database nor dispose it.
IMO, this way should be safer:
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect a polyline: ");
            peo.SetRejectMessage("Selected object is not a polyline.");
            peo.AddAllowedClass(typeof(Polyline), true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK) return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord space = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                Polyline pline = (Polyline)tr.GetObject(per.ObjectId, OpenMode.ForRead);
                using (Polyline clone = (Polyline)pline.Clone())
                    clone.ColorIndex = 1;
                    space.AppendEntity(clone);
                    tr.AddNewlyCreatedDBObject(clone, true);
                tr.Commit();
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
brianchapmandesign
Thanks giles, as always.
