PolyLine and Point2D and Point3D
conveyor1
conveyor1
Afternoon,
I have written some code to select a polyline and then assign the various points in the polyline to new variables.  However, I am running into the issue where the data I am getting from the polyline is 2d and the items downstream require 3D.
Here is an example:
Dim myPLine As Polyline
dim Num_Points as integer = myPLine.NumberOfVertices
Dim Point1 As New Geometry.Point2d     ' Needs to be .Point3d to work with the .Line command
Point1 = myPLine.GetPoint2dAt(Count)
Dim Myline1 As New DatabaseServices.Line(Point1, Point2)
In this case, everything up to the "Dim Myline1" works with 2d, but the line command requires 3d.
Does anyone have an solutions for this.
Please let me know when you can.
ActivistInvestor
You can use the GetPoint3dAt() method to get the WCS coordinate of a vertex.
@conveyor1wrote:
Afternoon,
Here is an example:
conveyor1
Morning,
Good call out and i did try this. However, if I switch, I then loose out
on the functionality of this line of code:
Angle2 = Point2.GetVectorTo(Point3).Angle
Do you know an equivalent to this calculation for the 3D option?
Please let me know your thoughts.
_gile
You should have a look at the Vector3d.GetAngleTo() method.
Assuming all the points lies on a plane parallel to the WCS XY plane, the equivalent for Vector2d.Angle should be:
Angle2 = Vector3d.XAxis.GetAngleTo(Point2.GetVectorTo(Point3), Vector3d.ZAxis);
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
ActivistInvestor
Go back and read your original question.
You didn't ask how to calculate angles between 3D coordinates, you asked how to get polyline vertices as 3D coordinates.
@conveyor1 wrote:
Morning,
Izhar_Azati
Note that if you use GetPoint2dAt, you get a point in ECS rather than WCS as you get from GetPoint3dAt
