PointMonitor and AutoSnap == 37
Do not know, if any of you have noticed or if it is already a known issue.
When you have a command and use the PointMonitor class, and then it is
changed the value of AutoSnap to 37 - The tooltip is not shown at all.
That's how was designed?
Thanks!
I solved my own question... thanks!
Luis, and the answer was ?
///kwb
wrote in message news:[email protected]...
By adding the following code inside of the event function:
[code]
// correccion de la variable autosnap!
object asnap = acadApp.GetSystemVariable("AUTOSNAP");
if (Convert.ToInt32(asnap).Equals(37))
object obj = 7;
acadApp.SetSystemVariable("AUTOSNAP", obj);
[/code]
That, way the tooltip is always shown.
My question was to know if this is a BUG - To me they are using the same tooltip as the one in autosnap - the problem is that why is broken if the value of autosnap is changed to 37 - when there could be other custom commands that rely on PointMonitor to provide info...
Luis, do you really think its ok to change the
user's preferences to get your program to work?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
[code]
object obj = 7;
[/code]
Tony;
This is for an in-house tools.
Thanks.
