PLT Dimensions C#
PLT Dimensions C#
PLT Dimensions C#
i'm building a .net program that needs to pull data from PLT file, the data is a drawing's dimensions in millimeters
how can i get info about the plt file in .net environment?
there is somthing like pdfreader in itextsharp.dll(for reading pdf)?
which SDK,Dll can you please suggest us some solution to this task?
I hope you have some tips. Many thanks!
BKSpurgeon
Hello
unfotunately that is not an area which i know anything about, but a simple google search yielding the following which you may find useful:
if you read and understand those links you're bound to learn something about plotting - probably enough to do whatever it is you need to do.
best rgds
BK
After many searches, I found what I needed.
Thank for the help,
Ced.
hello I have the same issue please can you help
